Home > Forums > Software User Forums > SU2 > SU2 Shape Design
Which basis function does SU2 employ in FFD technique of Shape Design Module?
Old   April 7, 2018, 04:26
Question Which basis function does SU2 employ in FFD technique of Shape Design Module?
Bingfei
lbfhappy is on a distinguished road
Hey all,
Which basis function does SU2 employ in FFD technique of Shape Design Module? Bernstein, B-Spline or NURBS? I learned these three basis functions from literature. May be it is another one that I didn't mentioned.
Bingfei
lbfhappy is offline   Reply With Quote
Old   April 15, 2018, 15:58
tom pratt
tomp1993 is on a distinguished road
Hi Bingfei,
please check the contents of config_template.py which would be included within your SU2 master file.
look for the line "FFD_BLENDING".
this provides options for you to use different types of basis functions according to your preference or design requirements.
best wishes
Tom
tomp1993 is offline   Reply With Quote
Old   April 19, 2018, 11:09
Bingfei
Thanks Tom for your reminding!
I found the "FFD_BLENDING" in the config_template.cfg. And I saw there's two option of the "FFD_BLENDING": BEZIER and BSPLINE_UNIFORM.
But I didn't use this function in my configuration file when doing shape optimization operation. So how can I know the basis function of FFD in SU2 by default?
Bingfei
Old   April 24, 2018, 07:25
Tim Albring
talbring is on a distinguished road
In the config_template.cfg file you can find all available config options along with their default values.
Tim
Developer Director @ SU2 Foundation
Get involved:
talbring is offline   Reply With Quote
Old   April 25, 2018, 10:12
Bingfei
Thanks Tim!
I think I understand and find the default basis function of FFD.
Bingfei
FFD shape deformation for 3D wing not changing the mesh lwc24 SU2 Shape Design 5 August 1, 2019 16:17
Error while running "Constrained Optimal Shape Design of a Fixed Wing" tutorial balav94 SU2 1 September 29, 2018 13:52
Problem with Tutorial "Constrained Optimal Shape Design of a Fixed Wing"" MarcF SU2 Shape Design 3 December 9, 2016 05:30
Question about SU2 optimization YoniHe SU2 Shape Design 3 January 15, 2016 01:31
Info: Short Course On Thermal Design of Electronic Equipment Arnold Free Main CFD Forum 0 August 10, 1999 11:18
