Home > Forums > Software User Forums > SU2 > SU2 Shape Design
shape_optimization.py calling nonexistant code in v.6?
Old   March 6, 2018, 10:40
Question shape_optimization.py calling nonexistant code in v.6?
tom pratt
tomp1993 is on a distinguished road
Hi everyone,
I'm running my own shape optimization following the new tutorial online, however when it comes time to calculate the gradients, a call is made to: /SU2-6.0.0/bin/SU2_CFD_AD
The process then terminates due to the fact that SU2_CFD_AD does not exist in this location?
the exact error message is as follows:
Command = mpirun -n 3 /users/user/SU2-6.0.0/bin/SU2_CFD_AD config_CFD_AD.cfg
SU2 process returned error '131'
mpirun was unable to launch the specified application as it could not access
or execute an executable:
Executable: /users/user/SU2-6.0.0/bin/SU2_CFD_AD
Node: comp11
while attempting to start process rank 0.
have i installed the package wrongly? i followed all the steps in the tutorial.
any help appreciated.
many thanks
Tom
tomp1993 is offline   Reply With Quote
Old   March 6, 2018, 10:41
tom pratt
P.S. i should mention that the flow function evaluation ran without any issues!
thanks
Old   March 8, 2018, 14:01
Default solved
tom pratt
The new SU2_AD package was not installed correctly.
Old   April 6, 2018, 06:14
kaush is on a distinguished road
Can you please elaborate on how to install SU2_AD properly. I am facing exactly the same issue when I run shape_optimization.py
kaush is offline   Reply With Quote
Old   April 15, 2018, 12:50
Thumbs up
tom pratt
you can either:
run shape optimization with the flag -g CONTINUOUS_ADJOINT if you do not want it to call SU2_AD.
or you can follow the online installation instructions https://su2code.github.io/docs/AD-Build/
Tom
adjoint solver, falcon, mpi, optimisation
The FOAM Documentation Project - SHUT-DOWN holger_marschall OpenFOAM 242 March 7, 2013 13:30
How to make code run in parallel? cwang5 OpenFOAM Programming & Development 1 May 30, 2011 05:47
Open Source Vs Commercial Software MechE OpenFOAM 28 May 16, 2011 12:02
Small 3-D code Zdravko Stojanovic Main CFD Forum 2 July 19, 2010 11:11
own Code vs. commercial code Bernhard Mueck Main CFD Forum 10 February 16, 2000 11:07
