Home > Forums > Software User Forums > SU2 > SU2 Shape Design
Help in Running Airfoil Problem
Old   October 8, 2017, 04:56
Default Help in Running Airfoil Problem
A. S.
apoorv is on a distinguished road
I am trying to run am airfoil problem for custom airfoil generator and grid generator I am using. I am not able to run the case it reads the grid then stops.
It stops after reading the mesh, but am clueless what is wrong. Any help would be kind. I can send the airfoil mesh file and cfg file if needed. I am not able to attach the file.
Thanks and Regards
Apurva
apoorv is offline   Reply With Quote
Old   October 8, 2017, 08:21
A. S.
Sorted out, airfoil grid format error
Ffd_control_point_2d feiyi SU2 4 September 30, 2019 13:42
ANSYS Licensing Problem, Processes Running but Showing as Not Running penguinman ANSYS 3 September 27, 2016 14:30
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 06:59
Fluid Structure Interaction problem for airfoil vinair39 OpenFOAM 0 February 8, 2011 08:57
Oscillating airfoil problem ganesh Main CFD Forum 2 June 27, 2005 14:57
