Home > Forums > Software User Forums > SU2 > SU2 Shape Design
Shape optimization: EFFICIENCY objective clarification.
Old   August 10, 2017, 08:39
Post Shape optimization: EFFICIENCY objective clarification.
Prakriteesh Sarma
fluxCatcher is on a distinguished road
Hi all,
One of the possible objectives listed in the SU2 config_template is "efficiency". The definition (expression) of efficiency will depend on the fluidic device being simulated (e.g. pump vs turbine, engine vs heat-pump etc..). Can someone please clarify which definition of efficiency is meant here, as a possible objective function?
Also, in particular, I am trying to optimize the efficiency of a free surface hydro-turbine. I know two phase flow capability is not in the current stable release of SU2. But is there a way to get around it to simulate free surface flow? (In the objective functions list, I can see an objective - "free_surface"). So wanted to confirm if free surface simulation is still possible?
Finally, by using discrete adjoint, it it possible to use custom objective functions?
Kind regards
Prakriteesh
fluxCatcher is offline   Reply With Quote
discrete adjoints, objective, objective function, shape optimization
what are the scaling factors of Optimization objective and constraint functions ? mechy SU2 Shape Design 4 September 22, 2017 04:23
Mesh not modified while shape optimization dolfyn SU2 Shape Design 0 May 3, 2017 22:20
SU2 Shape optimization questions AdriC SU2 Shape Design 6 January 27, 2016 05:25
Compressor design optimization for efficiency saisanthoshm88 CFX 0 September 9, 2014 16:11
Airfoil Shape Optimization using gradient based methods jaiswal Main CFD Forum 1 April 10, 2014 12:22
