Home > Forums > Software User Forums > SU2 > SU2 Shape Design
SU2 process was terminated by signal '11'
Old   June 22, 2017, 23:41
Question SU2 process was terminated by signal '11'
tom pratt
tomp1993 is on a distinguished road
i am trying to run shape_optimization.py on 5.0.0,
my input is :
/home/tomp/SU2/su2-5.0.0/bin/shape_optimization.py -f convoptcfg.cfg -n 0
and am returned:
|    ___ _   _ ___                                                      |
|   / __| | | |_  )   Release 5.0.0 "Raven"                             |
|   \__ \ |_| |/ /                                                      |
|   |___/\___//___|   Aerodynamic Shape Optimization Script             |
| SU2 Lead Dev.: Dr. Francisco Palacios, Francisco.D.Palacios@boeing.com|
|                Dr. Thomas D. Economon, economon@stanford.edu          |
| SU2 Developers:                                                       |
| - Prof. Juan J. Alonso's group at Stanford University.                |
| - Prof. Piero Colonna's group at Delft University of Technology.      |
| - Prof. Nicolas R. Gauger's group at Kaiserslautern U. of Technology. |
| - Prof. Alberto Guardone's group at Polytechnic University of Milan.  |
| - Prof. Rafael Palacios' group at Imperial College London.            |
| Copyright (C) 2012-2017 SU2, the open-source CFD code.                |
| SU2 is free software; you can redistribute it and/or                  |
| modify it under the terms of the GNU Lesser General Public            |
| License as published by the Free Software Foundation; either          |
| version 2.1 of the License, or (at your option) any later version.    |
| SU2 is distributed in the hope that it will be useful,                |
| but WITHOUT ANY WARRANTY; without even the implied warranty of        |
| MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU      |
| Lesser General Public License for more details.                       |
| You should have received a copy of the GNU Lesser General Public      |
| License along with SU2. If not, see <http://www.gnu.org/licenses/>.   |
Found: NSconemesh-78k-FFD.su2
Found: restart_flow.dat
New Project: ./
Removing old designs in 10s. Done!
Sequential Least SQuares Programming (SLSQP) parameters:
Number of design variables: 34 ( 34 )
Objective function scaling factor: [0.001]
Maximum number of iterations: 100
Requested accuracy: 1e-09
Initial guess for the independent variable(s): [0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0]
Lower and upper bound for each independent variable: [(-0.1, 0.1), (-0.1, 0.1), (-0.1, 0.1), (-0.1, 0.1), (-0.1, 0.1), (-0.1, 0.1), (-0.1, 0.1), (-0.1, 0.1), (-0.1, 0.1), (-0.1, 0.1), (-0.1, 0.1), (-0.1, 0.1), (-0.1, 0.1), (-0.1, 0.1), (-0.1, 0.1), (-0.1, 0.1), (-0.1, 0.1), (-0.1, 0.1), (-0.1, 0.1), (-0.1, 0.1), (-0.1, 0.1), (-0.1, 0.1), (-0.1, 0.1), (-0.1, 0.1), (-0.1, 0.1), (-0.1, 0.1), (-0.1, 0.1), (-0.1, 0.1), (-0.1, 0.1), (-0.1, 0.1), (-0.1, 0.1), (-0.1, 0.1), (-0.1, 0.1), (-0.1, 0.1)]
my env variables (SU2 HOME,RUN; PYTHONPATH) are all set correctly, i am using python 2.7.5 on Red Hat 4.8.5-11
any help appreciated?
Tom
tomp1993 is offline   Reply With Quote
Old   June 26, 2017, 13:02
Tim Albring
talbring is on a distinguished road
Hi Tom,
are you sure that '-n 0' is what you want (which means you want to run it with 0 cpus ) ?
Tim
talbring is offline   Reply With Quote
Old   June 26, 2017, 14:00
tom pratt
Hi tim,
I was trying to run it without mpi, I have also tried with -n 1 and without the n flag altogether. I get the same fault in all cases.
Thanks Tom.
Old   June 27, 2017, 04:48
Tim Albring
Ok, then add the option "-q FALSE" and paste the output (only the error maybe).
Old   June 28, 2017, 11:56
tom pratt
Hi Tim,
so i tried
/home/tp/SU2/su2-5.0.0/bin/shape_optimization.py -f convoptcfg.cfg -q FALSE
and again got:
./DESIGNS/DSN_001
after the usual intro.
the only files left in /DSN_001/DIRECT/ are config, mesh and restart flow dat file.
thanks
Tom
Old   March 1, 2018, 05:32
Exclamation
Bingfei
lbfhappy is on a distinguished road
I'm facing the same problem when I'm trying to run shape_optimization.py on 5.0.0 on a mesh made by myself.
Did you solve this problem Tom? @tomp1993
Does anyone know how to solve this problem?
Thanks!!!
lbfhappy is offline   Reply With Quote
python, signal 11, su2
[ImmersedBoundary] About the moving immersed boundary tutorial: icoDyMIbFoam+movingCylinderInChannelIco wyldckat OpenFOAM Community Contributions 25 September 14, 2021 18:15
Segmentation fault in SU2 V5.0 ygd SU2 2 March 1, 2017 05:38
The fl process could not be started because of UDF majid_kamyab Fluent UDF and Scheme Programming 6 December 15, 2015 09:42
VOF Transient Error rkanesan OpenFOAM Running, Solving & CFD 0 November 13, 2014 20:38
Backtrace errors while running on a HPC with buoyantBoussinesqSimpleFoam Thangam OpenFOAM Running, Solving & CFD 2 July 12, 2014 00:39
