January 30, 2017, 12:03 |
ROE scheme (turb M6)
tom pratt
Rep Power: 10 |
Hi Folks,
i'm a little confused right now, i've been trying to run the M6 wing RANS optimization with ROE scheme instead of JST, but can't seem to find much information on setting the AD_COEFF_FLOW correctly. this GitHub post (https://github.com/su2code/SU2/wiki/Turbulent-ONERA-M6) suggests that turb_ONERAM6.cfg is set up with ROE scheme, but when found at (https://github.com/su2code/SU2/blob/...rb_ONERAM6.cfg), we see that the JST scheme is used. I would like to use ROE since JST does not satisfy the Reimann problem for shockwaves and seems to smear the discontinuity significantly. I've also tried setting up my own 2D supersonic aerofoil problems using Roe scheme unsuccessfully, however again, JST returns a very well converged solution but with shockwave smearing. any help or pointers would be appreciated. cheers. |
ad_coeff., jst, m6 wing, roe |
Roe matrix for Finite volume scheme. | dokeun | Main CFD Forum | 6 | March 1, 2018 11:00 |
Roe scheme and kw model | Joachim | Main CFD Forum | 9 | July 5, 2017 19:02 |
Roe Flux Difference Splitting Scheme in Cylindrical Coordinate System | _inferno_ | Main CFD Forum | 0 | November 8, 2013 04:10 |
Roe flux scheme, why Roe's averages important | Shenren_CN | Main CFD Forum | 9 | April 19, 2013 14:26 |
Roe scheme unstablity | ricklee | Main CFD Forum | 2 | October 26, 2005 09:40 |
