Prevent intersection of upper and lower side of airfoil |
January 29, 2017, 04:54 |
Rep Power: 12 |
Hello everybody,
I want to optimize a 2D Naca0018 to maximize lift. However, after several design evaluations the upper and lower side of the airfoil start to intersect with each other (see fig attached). I tried to prevent this with constraints in the thickness ( 1/4_THICKNESS > ..., 1/2_THICKNESS > ... and so on) ... but this didn't work out ... the airfoil sides still overlap at certain designs. Sometimes this leads to diverging in the direct simulation sometimes not, and the final design consist of 2 individual smaller airfoils. What is a good way to prevent this? Which constraints to use that don't restrict the optimization process too much... Thank you very much! (PS: Also, the optimizations seems to ignore the specified upper and lower bounds for the design variables, which lie at 1.5 and -1.5. Version SU2_V5.0 Raven) |
March 6, 2017, 09:49 |
Floris
Rep Power: 9 |
Hi Beatlejuice,
Can you also provide us your .cfg file, history_project file and the log files of the direct and adjoint simulations of the last design (I do not mean the last line search design ). Thank you in advance! Kind regards, Floris |
Problems finishing implementation of 2D Linear-Strength Vortex Method (Airfoil) | al3x | Main CFD Forum | 4 | October 5, 2017 10:56 |
[snappyHexMesh] upper and lower patch for a 0_thick Membrane in a wind tunnel | hfs | OpenFOAM Meshing & Mesh Conversion | 7 | October 15, 2013 16:41 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 05:59 |
NACA 4412 upper and lower surface crest | fxzf | Main CFD Forum | 0 | February 11, 2010 12:11 |
Airfoil boundary condition | Frank | Main CFD Forum | 1 | April 21, 2008 18:36 |
