V4.0.0 Got stuck at the beginning of optimization |
July 30, 2015, 23:08 |
Antoni Alexander
Rep Power: 17 |
After update to v4.0.0 from 3.2.3, I start to run the test case downloaded along with the new version. The rans cases such as Rae2822, m6 are fine. But when I come to optimization_rans/steady_rae2822 or steady_oneram6, the program gets stuck as the picture shows.
Does anyone know the reason? How to solve it? By the way, everything was fine when I using v3.2.3 on this cluster.ImageUploadedByCFD Online Forum1438308504.932654.jpgImageUploadedByCFD Online Forum1438308521.215181.jpg |
August 8, 2015, 20:20 |
#2 | |
Heather Kline
Rep Power: 14 |
Output will only be generated to the screen at the end of each major iteration, and every iteration (line searches included) will be output to a history file as well as the individual DSN_* folders. |
August 9, 2015, 05:41 |
Antoni Alexander
Rep Power: 17 |
Yes, it is really as you said that there is a log file. Thanks hlk!
3D design optimization in a rotating frame? | ITA91 | SU2 Shape Design | 2 | May 20, 2015 11:01 |
Airfoil Shape Optimization using gradient based methods | jaiswal | Main CFD Forum | 1 | April 10, 2014 12:22 |
Total force optimization or pressure force optimization? | robyTKD | SU2 Shape Design | 1 | August 19, 2013 16:54 |
COMSOL: optimization applied to a laminar flow | tdh89 | COMSOL | 0 | April 30, 2012 09:57 |
BOOK ON OPTIMIZATION OF FORTRAN CODES | Alberto | Main CFD Forum | 3 | November 10, 2008 07:07 |
