Albin Johny
Rep Power: 11 ![]() |
I am trying to do a Pitching and plunging case of an airfoil in SU2.
The plunging works properly but the pitching motion is not occuring. The DYNAMIC MESH DEFINITION I have used is shown below % ----------------------- DYNAMIC MESH DEFINITION -----------------------------% % % Mesh motion for unsteady simulations GRID_MOVEMENT= YES % % Type of mesh motion GRID_MOVEMENT_KIND= RIGID_MOTION % % Marker(s) of moving surfaces (MOVING_WALL or DEFORMING grid motion) MARKER_MOVING= airfoil % % Mach number (non-dimensional, based on the mesh velocity and freestream vals.) MACH_MOTION= 0.3 % % Coordinates of the rigid motion origin MOTION_ORIGIN_X= 0.5 MOTION_ORIGIN_Y= 0.0 MOTION_ORIGIN_Z= 0.0 % % Translational velocity (m/s) in the x, y, & z directions (RIGID_MOTION only) TRANSLATION_RATE_X = 0.0 TRANSLATION_RATE_Y = 0.0 TRANSLATION_RATE_Z = 0.0 % % Angular velocity vector (rad/s) about x, y, & z axes (RIGID_MOTION only) ROTATION_RATE_X = 0.0 ROTATION_RATE_Y = 0.0 ROTATION_RATE_Z = 0.0 % % Pitching angular freq. (rad/s) in x, y, & z directions (RIGID_MOTION only) PITCHING_OMEGA_X= 0.0 PITCHING_OMEGA_Y= 183.6 PITCHING_OMEGA_Z= 0.0 % % Pitching amplitude (degrees) in x, y, & z directions (RIGID_MOTION only) PITCHING_AMPL_X= 0.0 PITCHING_AMPL_Y= 20.0 PITCHING_AMPL_Z= 0.0 % % Pitching phase offset (degrees) about x, y, & z axes (RIGID_MOTION only) PITCHING_PHASE_X= 0.0 PITCHING_PHASE_Y= 90 PITCHING_PHASE_Z= 0.0 % % Plunging angular freq. (rad/s) in x, y, & z directions (RIGID_MOTION only) PLUNGING_OMEGA_X= 0.0 PLUNGING_OMEGA_Y= 183.6 PLUNGING_OMEGA_Z= 0.0 % % Plunging amplitude (m) in x, y, & z directions (RIGID_MOTION only) PLUNGING_AMPL_X= 0.0 PLUNGING_AMPL_Y= 1.0 PLUNGING_AMPL_Z= 0.0 %------------------------------------------------------------------------------------------------------% Can anyboby please help me to sort the problem Any suggessions are Welcome. |
Albin Johny
I got the solution to the problem. And my pitching is coming properly.
But now i am facing a new problem ie when I put omega of 102 the pitching occurs and if i increase the omega to 122 it diverges can anybody help me |
su2 transition point and output settings | varghese9 | SU2 | 2 | March 5, 2015 12:13 |
sliding mesh of SU2 | mistuning | SU2 | 1 | January 11, 2014 22:23 |
Airfoil pitching problem | montag dp | FLUENT | 12 | June 25, 2012 06:25 |
Pitching and Plunging Oscillation with Broadband forcing | salihovic | FLUENT | 0 | February 6, 2011 12:36 |
