June 13, 2015, 04:37 |
Sharp edge coeff
Rep Power: 11 |
Hi, i'm doing the optimization of a multi element airfoil with the FFD method. I leave the trailing edge of the main profile out of the box, and for guarantee the deformation continuity i increase the SHARP_EDGE_COEFF. This works well, but i want to know if there is documentation about this option. I'm writing my graduation thesis on the SU2 shape optimization and i want to explain better the function of this parameter. Thank you in advance.
July 14, 2015, 17:22 |
Andrw Wendorff
Rep Power: 12 |
SHARP_EDGE_COEFF is usually used for removing sensitivity at sharp edges that are used in mesh deformation or limiting in the numerical methods. It is not usually used for deformation continuity. The FFD deformation follows the typical structure with minor variations for best practices. These best practices are not summarized in a formalized document.
July 23, 2015, 19:18 |
#3 | |
Heather Kline
Rep Power: 14 |
In the code this setting is used in: CSurfaceMovement::CheckFFDIntersections (grid_movement_structure.cpp) |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 07:09 |
[ICEM] Hole near sharp trailing edge of airplane/wing geometry | jlichtwa | ANSYS Meshing & Geometry | 2 | September 21, 2010 16:19 |
Actuator disk model | audrich | FLUENT | 0 | September 21, 2009 08:06 |
Where's the singularity/mesh flaw? | audrich | FLUENT | 3 | August 4, 2009 02:07 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
