Home > Forums > Software User Forums > SU2 > SU2 Shape Design
Sharp mesh deformation at FFD intersection
Old   May 6, 2015, 18:08
Default Sharp mesh deformation at FFD intersection
Ross
RonSwanson is on a distinguished road
I have been trying to optimise a nozzle for maximum mass flow/discharge coeff. The flow solver and adjoint converge well. However The FFD box creates very jagged intersections with non deforming part of the wall.
I have tried to modify my FFD box in numerous ways through position and size, as well as the numerous .cfg controls for optimisation. I have attached some pictures.
This has also occurred when using Hicks-Henne.
Does anybody have any suggestions?
I have also found a minor bug when optimising for mass flow:
-Adjoint solver creates adjres_mfr.dat
-Optimiser calls adjres_mfw.dat, causing it to fail
-The bug is located in bin/SU2/io/tools.py -- line 431
Regards,
Ross.
RonSwanson is offline   Reply With Quote
Old   May 9, 2015, 09:02
Ross
My supervisor suggested a fix, which works perfectly. If you create an extra 2 FFD sections either side of the, deformable area and set them to 0 degrees of freedom then you lock the geometry of these sections and the curvature throughout is smoothed.
Cheers,
Ross.
Edit (13/05/15): Sorry all a further issue I have come across is the way the solver treats the objective mass flow function. My nozzle was attempting to shrink itself and thus choke, reducing mass flow. In my case I want to maximize mass flow, I'm not sure if it's a bug but again in tools.py line 360 the following is present
# Get Objective Function Sign
def get_objectiveSign( ObjFun_name ):
""" returns -1 for maximization problems:
LIFT
EFFICIENCY
THRUST
FIGURE_OF_MERIT
returns +1 otherwise
# flip sign for maximization problems
if ObjFun_name == "LIFT" : return -1.0
if ObjFun_name == "EFFICIENCY" : return -1.0
if ObjFun_name == "THRUST" : return -1.0
if ObjFun_name == "FIGURE_OF_MERIT" : return -1.0
# otherwise
return 1.0
#: def get_objectiveSign()
I have edited it to and this could be perfromed with any other obj. func.
LIFT
EFFICIENCY
THRUST
FIGURE_OF_MERIT
if ObjFun_name == "MASS_FLOW_RATE" : return -1.0
# otherwise
return 1.0
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
CFX interpolating to a mesh with deformation martindg CFX 5 October 17, 2012 06:52
mesh deformation - mesh stiffness alfonsojurado CFX 6 October 2, 2012 08:15
Mesh deformation, negative volume! Turbomachine CFX 12 June 9, 2011 09:05
[GAMBIT] 3D mesh for pipe intersection pranab_jha ANSYS Meshing & Geometry 3 May 28, 2010 02:33
