How to create a ffd box in the su2 mesh file? |
chenbojian
Rep Power: 11 ![]() |
I am trying to do an optimization on f6. But I'm not quiet sure about how to create the ffd box or how to set the ffd controll points after I create the mesh file. I found a tool(createFFD) published by pointwise in github . Is this the right one? And how should I set the design variables in .cfg file??
Andrw Wendorff
Rep Power: 12 ![]() |
You can do this directly from the config file using the section FREE-FORM DEFORMATION PARAMETERS in the config_template.cfg (lines 759-778).
design varibles, ffd, su2 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 19:43 |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 03:23 |
[swak4Foam] Error bulding swak4Foam | sfigato | OpenFOAM Community Contributions | 18 | August 22, 2013 12:41 |
friction forces icoFoam | ofslcm | OpenFOAM | 3 | April 7, 2012 10:57 |
ParaView Compilation | jakaranda | OpenFOAM Installation | 3 | October 27, 2008 11:46 |
