Home > Forums > Software User Forums > SU2 > SU2 Shape Design
Lower surface gradients are zero
Old   November 27, 2014, 14:56
Default Lower surface gradients are zero
Aidan
amcloughlin801 is on a distinguished road
Whenever I try to run continuous_adjoint.py on my case, the gradients for design variables 0-18 (ie the lower surface) are zero.
Does anyone know why this might be happening?
I've attached my config file and gradient output file.
Thanks
Aidan
amcloughlin801 is offline   Reply With Quote
Old   November 27, 2014, 19:05
Khiem Pham
Bachduong is on a distinguished road
Hi
Could you please send me your mesh .SU2?
Here is my config file
Bachduong is offline   Reply With Quote
Old   November 27, 2014, 19:23
Aidan
Thanks for offering to take a look! Can you send me a private message with your email address and I'll send it to you? I can't upload *.su2 files as a message on here.
Cheers,
Aidan
Old   November 27, 2014, 21:27
Khiem Pham
My email is van.fam@phystech.edu.
Thank you.
Old   November 28, 2014, 09:38
Aidan
Hi Bachduong
I think there is a problem with my mesh, as my config is identical to the steady_rae2822 test case.
Have you had a look at the mesh?
Thanks
Aidan
Old   November 28, 2014, 12:40
Khiem Pham
Unfortunately, the code doesn't convergence.
Old   November 29, 2014, 06:12
Khiem Pham
Do you have mesh file in other format? I want to check mesh with Ansys Fluent.
Old   January 4, 2015, 04:56
Thomas D. Economon
economon is on a distinguished road
Were you guys able to straighten this issue out? Aidan, were you able to successfully run some of the optimization cases that come in the Test Cases folder to make sure that there isn't an issue with your SU2 installation?
Cheers,
Thomas D. Economon
SU2 lead developer
economon is offline   Reply With Quote
Old   January 4, 2015, 06:06
Aidan
Hi Tom,
Unfortunately I wasn't able to fix it, no. The test cases work fine so I'm just using the test case mesh instead.
Cheers
Aidan
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 12:05
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 13:43
Recover surface from surface mesh in IcemCFD Jerry Tanner CFX 0 August 20, 2008 13:48
Patran Volume Meshing Deb CFX 19 April 17, 2003 11:56
free convection heat transfer from a heated horizontal surface through a liquid to a thin cooled fin Kaushik FLUENT 1 May 8, 2000 07:47
