Home > Forums > Software User Forums > SU2 > SU2 Shape Design
shape optimization for RAE2822 with constraint on area
Old   September 9, 2014, 11:46
Default shape optimization for RAE2822 with constraint on area
Mengmeng is on a distinguished road
Hi
I am new to SU2, and tried to optimize RAE2822 with a number of constraints. One is the airfoil Area > initial_Area.
So I set:
OPT_CONSTRAINT= ( LIFT > 0.824 ) * 0.001; ( MOMENT_Z > -0.092 ) * 0.001; ( EQUIVALENT_AREA > 0.07787 ) * 0.001
the errors I got:
------------------------- Exit Success (SU2_CFD) ------------------------
done: 0.8478197895
Moment_Z... done: 0.1048105494
Equivalent_Area... Traceback (most recent call last):
File "/usr/local/SU2/bin/shape_optimization.py", line 130, in <module>
main()
File "/usr/local/SU2/bin/shape_optimization.py", line 75, in main
options.step )
File "/usr/local/SU2/bin/shape_optimization.py", line 113, in shape_optimization
SU2.opt.SLSQP(project,x0,xb,its)
File "/usr/local/SU2/bin/SU2/opt/scipy_tools.py", line 102, in scipy_slsqp
epsilon = 1.0e-06 )
File "/usr/lib/python2.7/dist-packages/scipy/optimize/slsqp.py", line 236, in fmin_slsqp
mieq = len(f_ieqcons(x))
File "/usr/lib/python2.7/dist-packages/scipy/optimize/optimize.py", line 176, in function_wrapper
return function(x, *args)
File "/usr/local/SU2/bin/SU2/opt/scipy_tools.py", line 187, in con_cieq
cons = project.con_cieq(x)
File "/usr/local/SU2/bin/SU2/opt/project.py", line 223, in con_cieq
return self._eval(konfig, func,dvs)
File "/usr/local/SU2/bin/SU2/opt/project.py", line 172, in _eval
vals = design._eval(func,*args)
File "/usr/local/SU2/bin/SU2/eval/design.py", line 132, in _eval
vals = eval_func(*inputs)
File "/usr/local/SU2/bin/SU2/eval/design.py", line 422, in con_cieq
func = su2func(this_con,config,state)
File "/usr/local/SU2/bin/SU2/eval/functions.py", line 94, in function
func_out = state['FUNCTIONS'][func_name]
KeyError: 'EQUIVALENT_AREA'
when I removed the area constraint it works fine.
Can anyone help me with it? I also tried different scaling factor but no help
thanks
Mengmeng is offline   Reply With Quote
Old   September 21, 2014, 22:39
Francisco Palacios
fpalacios is on a distinguished road
Oops... EQUIVALENT_AREA area is related with the supersonic Area Rule (this is for minimizing the sonic boom in supersonic aircraft design one of SU2 specialties).
Best,
Francisco
fpalacios is offline   Reply With Quote
Old   September 22, 2014, 06:41
Hi thanks a lot Francisco, but then how can I put the constraint on the airfoil area?
note that the constraint is not about the thickness but the total area is no less than the original.
maybe I should use "AREA" instead.
but then the question is the quatity, in the reference area I set (for airfoil) REF_AREA = 1, so can I set the constraint on area as "( AREA > 1 ) * scale" ?
thanks for your help
Best,
Francisco
Old   September 29, 2019, 19:23
cfdjetman
cfdjetman is on a distinguished road
I'm doing the exact same case in SU2 6.2. I used AIRFOIL_AREA >0.0778. However, when I can calculate the area of the airfoil of the optimized shape it is typically around 0.0700. I'm not sure how not to violate this constraint.
I had couple of questions.
1. How does the scaling factors on the objective function and constraints affect them? Currently, I just use a scaling factor of 1. What if I used 0.001 instead?
2.Do I need to change the optimizer accuracy accordingly? For e.g, if I used 1e-06 for the drag objective function with scaling factor of 1, do I need to change this to 1e-09 for scaling factor of 0.001?
3. Is there any way of viewing the area of an airfoil in SU2? I currently use the surface file to calculate the airfoil area in MATLAB.
4. As mentioned above, how not to violate the area constraint?
Thanks
cfdjetman is offline   Reply With Quote
help needed
Non overlap area fractions saisanthoshm88 CFX 13 December 11, 2024 17:03
what are the scaling factors of Optimization objective and constraint functions ? mechy SU2 Shape Design 4 September 22, 2017 04:23
Airfoil Shape Optimization using gradient based methods jaiswal Main CFD Forum 1 April 10, 2014 12:22
Shape Optimization Error, Incorrect values produces by SU2_GDC Dhig SU2 Shape Design 1 March 20, 2014 06:58
CFX Solver Memory Error mike CFX 1 March 19, 2008 08:22
