February 14, 2014, 13:34 |
Test case for rans optimization?
何建东
Rep Power: 13 |
Hello developers.
Are there any test cases for rans optimization? thanks |
February 16, 2014, 00:10 |
Thomas D. Economon
Rep Power: 14 |
There are a number of shape design examples that can be found in the TestCases directory. Please see TestCase/optimization_rans/ for a set of several examples. You should find rans-based design cases for both an airfoil and a wing there. Hope this helps, Tom |
February 18, 2014, 02:22 |
#3 | |
何建东
Rep Power: 13 |
and another question, i want to carry out some optimization for super/hypersonic flows. can SU2 realize it? or can u give me some suggestion.? Thank u |
February 24, 2014, 00:04 |
#4 | |
Thomas D. Economon
Rep Power: 14 |
http://adl.stanford.edu/papers/AIAA_Paper_ASM_2012.pdf Adjoint-Based Aerothermodynamic Shape Design of Hypersonic Vehicles in Non-Equilibrium Flows (AIAA 2014-0513) |
March 3, 2014, 02:06 |
#5 | |
何建东
Rep Power: 13 |
Now i have other questions. i tried to realize rans optimization with my own grid! but some times the optimization converged only in the first step! some times the optimization collapsed after 2 steps due to the large grid deformation, and there are negative volumes or bad quality grids.. how to solve this problem?? i know that SU2_CFD support Hexahedral elements, could i use Hexahedral elements in optimization...does FEA mesh deformation support this kind of elements? because i have seen the test case of rans M6 used Tetrahedral boundary layers, bui i don,t know how to creat this kind of mesh with pointwise. |
March 3, 2014, 17:19 |
#6 | |
Tommy Chen
Rep Power: 15 |
Using pointwise to generate Tetrahedral elements as boundary layer is quite basic and easy, you could use the T-rex functionality of Pointwise V17. Here is a link of video on youtube, I think it is a good toturial for you to learn Pointwise as a beginner. http://www.youtube.com/watch?v=uz661XzE1QE How T-Rex Unstructured Meshing Aids Transonic Aircraft Drag Reduction Tommy |
March 3, 2014, 22:06 |
#7 | |
何建东
Rep Power: 13 |
Viscositymodel tutorial, problems when changing test case to cavity | sur4j | OpenFOAM Programming & Development | 1 | December 8, 2013 10:53 |
T3c2 flat plate test case | rajeshamech | Main CFD Forum | 0 | November 21, 2013 06:21 |
Interfoam Droplet under shear test case | adona058 | OpenFOAM Running, Solving & CFD | 3 | May 3, 2010 19:46 |
Porous Media test case | Alex | FLUENT | 0 | April 9, 2006 09:23 |
c1 body test case | Eric Lenormand | Main CFD Forum | 0 | March 2, 2000 07:54 |
