Error in optimization of the RAE2822 airfoil with the mesh in the test case |
May 21, 2013, 01:14 |
#21 |
Francisco Palacios
Rep Power: 15 |
The new developer version 2.0.4 is now available. In this version we have improved a lot the stability of the direct solver. Give it a shot and increase the CFL number (Krylov based linear solvers are highly recommended) Cheers, Francisco |
May 29, 2013, 07:30 |
#22 | |
Tommy Chen
Rep Power: 15 |
I could run Su2 v2.0.4 well on rans optimization with airfoils, but when the frozen_vicosity option is NO, the iteration seems to diverge all the time. Have you done a statisfied case with the frozen_viscosity=NO with rans airfoil optimization ? Tommy |
May 29, 2013, 07:32 |
#23 | |
Tommy Chen
Rep Power: 15 |
Could the current version handle the adjoint withle the frozen_viscosity equals to NO ? I have tried but the iteration seems to diverge all the time on a testcase of RAE2822 airfoil. Tommy |
May 30, 2013, 03:28 |
#24 |
Anant Diwakar
Rep Power: 13 |
Hi Tommy
I ran RANS based shape design on RAE2822 airfoil and obtained 2.5 % reduction in drag, I used Frozen viscosity parameters as 'Yes'. I tried to run the case with Frozen viscosity parameter as 'No', but the case was not able to run and gave error after 1st flow solution. The log and configuration file is attached. Thanks Anant |
May 30, 2013, 06:09 |
#25 | |
Tommy Chen
Rep Power: 15 |
Anant I guess it is due to the absence of the Adjoint_Turbulent_Options , please check the configuration_template. Tommy |
May 30, 2013, 06:21 |
#26 |
Anant Diwakar
Rep Power: 13 |
Hi Tommy
Can you share the configuration file ? Thanks Anant |
May 30, 2013, 06:37 |
#27 |
Anant Diwakar
Rep Power: 13 |
Hi Tommy
Are you referring to CONV_NUM_METHOD_ADJTURB parameter ? I am using nearly the same configuration file posted in this link (post no. 18) by Francisco, in which too, this parameter is missing. Even if we don't mention this parameter explicitly, won't SU2 take some default parameter for this variable ? Can you share the configuration file used by you ? Thanks Anant |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 07:09 |
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 04:19 |
[Other] 2D hex mesh on multi element airfoil | Verfblikje | OpenFOAM Meshing & Mesh Conversion | 0 | January 19, 2012 11:55 |
[snappyHexMesh] SnappyHexMesh not generate mesh first time | mavimo | OpenFOAM Meshing & Mesh Conversion | 4 | August 26, 2008 08:08 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 10:38 |
