July 2, 2024, 03:30 |
How to specify mfr conditions in CFG file
Rep Power: 6 |
I have a simple 3-D inlet geometry with 2 control faces, inlet and outlet (exhaust) in a spherical farfield. I wish to run this at free-stream Mach 0.8.
Could someone please help in setting this for mfr of 0.6 at the inlet face and (say) Mach 1 at the exhaust face What lines do I need to specify in the CFG file. Do the areas of the faces come into this ...... May be there is an example in tutorials ? Many thanks |
July 3, 2024, 07:42 |
bigfoot
Rep Power: 18 |
I do not understand the setup, how can you have an inlet and an outlet together with a spherical farfield? Is there a wormhole in the domain? Do you have a sketch?
July 4, 2024, 02:26 |
Rep Power: 6 |
Yes, I should have mentioned the word "nacelle"
Just thinking in terms of a simple engine nacelle eg. on a 737 aircraft: Downstream of the lip, a control face that requires MFR and then another control face closing the nacelle simulating the exhaust conditions. Thanks |
boundary condition, contrpl-faces, intakes |
[swak4Foam] Installation Problem with OF 6 version | Aurel | OpenFOAM Community Contributions | 14 | November 18, 2020 16:18 |
OpenFoam "Permission denied" and "command not found" problems. | iyidaniel@yahoo.co.uk | OpenFOAM Running, Solving & CFD | 11 | January 2, 2018 06:47 |
Trouble compiling utilities using source-built OpenFOAM | Artur | OpenFOAM Programming & Development | 14 | October 29, 2013 10:59 |
friction forces icoFoam | ofslcm | OpenFOAM | 3 | April 7, 2012 10:57 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
