February 5, 2024, 04:40 |
Google Summer of Code 2024
bigfoot
Rep Power: 18 |
The SU2 Foundation is applying for Google Summer of Code 2024! From all the possible projects, we have made a selection of 5 topics that could be used in a GSoC project. The document can be viewed here:
https://docs.google.com/document/d/1...it?usp=sharing edit: please also see the other post on How To Apply: GSoC Applications - How to Apply Last edited by bigfootedrockmidget; February 6, 2024 at 17:57. |
February 5, 2024, 04:41 |
bigfoot
Rep Power: 18 |
For completeness, the 5 projects that were selected are given below:
Project 1: Differentiated Meshing for CFD-based Design
Project 2: Extending Python Wrapper with Tabulated Thermodynamics and Chemistry
1: The reference data is interpolated through a (structured) look-up table, presented through the python wrapper of SU2. 2: The table format and look-up feature shall support an arbitrary number of table dimensions. 3: Emphasis lies on high interpolation accuracy with robust and efficient performance in terms of memory usage and query time.
Other ideas can also be supported if you have a novel idea that matches your specific knowledge and interests (improving specific turbulence models for instance), but you need to find a mentor to supervise the project. Last edited by bigfootedrockmidget; February 21, 2024 at 03:15. Reason: formatting |
gsoc |
water injection error (modify the position of water injection) | wjchoi | Main CFD Forum | 0 | January 17, 2022 07:17 |
How to make CFD code architechture flexible enough for future modifications? | aerosayan | Main CFD Forum | 6 | September 3, 2021 04:35 |
Fortran->Assembly : How to remove redundant non-vectorized code? | aerosayan | Main CFD Forum | 6 | November 20, 2020 05:37 |
The FOAM Documentation Project - SHUT-DOWN | holger_marschall | OpenFOAM | 242 | March 7, 2013 12:30 |
Small 3-D code | Zdravko Stojanovic | Main CFD Forum | 2 | July 19, 2010 10:11 |
