October 21, 2024, 06:43 |
SU2 Installation error with mpich
Ercan Umut
Rep Power: 4 |
Hello Everybody,
I am trying to use SU2 with mpich as SU2's webpage suggests. When configuring I am using the command below: Code:
./meson.py build -Denable-autodiff=true -Denable-pywrapper=true -Denable-mpp=true -Dwith-mpi=enabled -Dcustom-mpi=true -Dextra-deps=mpich -prefix=home/directory Code:
export MPICC=/usr/bin/mpicc export MPICXX=/usr/bin/mpicxx export CC=$MPICC export CXX=$MPICXX Code:
Abort(70871301) on node 0: Fatal error in internal_Comm_rank: Invalid communicator, error stack: internal_Comm_rank(30212): MPI_Comm_rank(comm=0x2feb8c20, rank=0x5bff1f33fc48) failed internal_Comm_rank(30166): Invalid communicator The reason I am explaning this is I want to use Python Wrapper function so I can specify a custom inlet that comes with SU2v8.1. When I use regular cc and c++ for installation and do Code:
import sys import pysu2 import math from mpi4py import MPI def main(): """ Run the flow solver with a custom inlet (function of time and space). """ comm = MPI.COMM_WORLD # comm = 0 . . . Code:
Attempting to use an MPI routine (internal_Comm_rank) before initializing or after finalizing MPICH Last edited by CleverBoy; October 21, 2024 at 17:19. |
October 24, 2024, 12:29 |
Sakun
Rep Power: 7 |
I had pretty much your issue and then i have found this video. It is really straight forward to follow. https://www.youtube.com/watch?v=SOh6...c2tYF&index=39 Hope this helps, |
Installation error with SU2 - Adjoint | cfd-jg | SU2 Installation | 0 | December 18, 2023 07:55 |
SU2 v7.2.1 Installation error on macOS Catalina | wertyfg | SU2 Installation | 0 | January 17, 2022 15:37 |
Introducing SU2 International Developers Society (IDS) | fpalacios | SU2 News & Announcements | 1 | June 17, 2019 23:38 |
SU2 Installation on Windows 32 bit | niddaas | SU2 Installation | 3 | May 6, 2016 18:03 |
SU2 parallel installation error | JAlbert | SU2 Installation | 2 | November 19, 2013 03:43 |
