January 17, 2023, 08:08 |
SU2 installation error
Arkesh Anjananand Sikha
https://drive.google.com/file/d/1JSm...ew?usp=sharing
An error occurred after I executed the ninja command to compile the software. Did any of you experience the same error? If yes, how did you solve it? I have attached the link to the screenshot showing the error. |
January 17, 2023, 09:05 |
Wally Maier
Rep Power: 7 |
Did you do a clean install? Or were you trying to update from an older branch? It looks like the make files may be out of date. I would suggest doing: 1.) "rm -r build" in your base directory. 2.) rerunning the meson.py commands 3.) rerun ninja |
[swak4Foam] swak4foam openfoam 7 installation problem | Andrea23 | OpenFOAM Community Contributions | 1 | February 17, 2020 18:11 |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 09:00 |
DPM udf error | haghshenasfard | FLUENT | 0 | April 13, 2016 06:35 |
Errors in UDF | shashank312 | Fluent UDF and Scheme Programming | 6 | May 30, 2013 20:30 |
How to get the max value of the whole field | waynezw0618 | OpenFOAM Running, Solving & CFD | 4 | June 17, 2008 05:07 |
