Home > Forums > Software User Forums > SU2 > SU2 Installation
"options.filename == None" occurs in all .py files under windows10
Old   March 21, 2022, 11:23
Default "options.filename == None" occurs in all .py files under windows10
Qiulin
qren3 is on a distinguished road
This is a SU2 user using Windows 10 system. When simulating the Tutorial Case, as long as SU2_CFD is used, it can be successfully simulated, but the parallel_computation.py required by my project cannot be used. Also, all simulations with ".py" files suffer from the same problem, i.e. "options.filename == None".
I wonder if this situation is a problem with the Python Wrapper? The tutorial does not mention its compilation method in Windows system. I would like to report how to use the parallel_computation.py in Windows system?
My SU2 version is v7.3.0.
I will be very appreciated if I could get some feedback on this issue.
qren3 is offline   Reply With Quote
su2
Converting ANSYS CFX files to Fluent files Martin S. Rasmussen FLUENT 3 January 30, 2007 16:08
Problems with result files Kasper CFX 5 December 14, 2006 03:41
Results saving in CFD hawk Main CFD Forum 16 July 21, 2005 21:51
[making animations] fclose fails to close files? Mika FLUENT 0 March 30, 2001 09:19
Merging .msh files in TGrid Raza Mirza FLUENT 2 January 18, 2001 19:09
