February 10, 2020, 09:50 |
SU2 Installation Error on CentOS 7
Andre F. C. da Silva
I'm having trouble compiling the SU2 7 from source on CentOS 7 for a while.
Meson seem to run properly and the configuration step seems ok. However during compilation via ninja, there seems to be a problem with the linker while linking the SU2_CFD: /stuff/easybuild/eb-install/software/binutils/2.31.1-GCCcore-8.2.0/bin/ld.gold: fatal error: /stuff/easybuild/eb-install/software/OpenMPI/3.1.3-GCC-8.2.0-2.31.1/lib: pread failed: Is a directory As you can see, I've used GCCcore 8.2.0 and OpenMPI 3.1.3, but the issue persists with other versions of the compilers. Any thoughts? |
March 24, 2022, 08:15 |
Dan-Gabriel CALUGARU
Your question is a bit old and maybe you already solved the problem, but since there is no answer and I faced with the same error (all on CentOS7), here is the solution that worked for us and who may be usefull for someone else : install and use a newer version of pkg-config
Indeed, the pkg-config version from CentOS7 (0.27.1) seems to be too old and not suitable for this SU2 installation, while using pkg-config version 0.29.2 (even if it is also old , but it's the last one available) makes this error disappear. Best regards, Dan |
Introducing SU2 International Developers Society (IDS) | fpalacios | SU2 News & Announcements | 1 | June 17, 2019 23:38 |
SU2 Installation on Windows 32 bit | niddaas | SU2 Installation | 3 | May 6, 2016 18:03 |
[OpenFOAM.org] OpenFOAM 2.3.0 Installation Problem on CentOS 6.6 | shenzhou1987 | OpenFOAM Installation | 1 | December 14, 2014 14:34 |
SU2 parallel installation error | JAlbert | SU2 Installation | 2 | November 19, 2013 03:43 |
Can I compile SU2 in CentOS? | sxhqjfl | SU2 Installation | 2 | April 11, 2013 20:23 |
