October 5, 2018, 04:45 |
SU2_CFD run error [SOLVED]
Bhupinder Singh Sanghera
Rep Power: 8 |
Hi there,
The past week I have installed Ubuntu 16.04 LTS as a dual boot on my laptop alongside with Windows 10. I have been trying to install SU2 on my Ubuntu 16.04 LTS. I have tried to install using 'Build from source' and the 'simple build' option. I have followed all the steps (see https://su2code.github.io/docs/Simple-Build/) which seem to be utterly simple and yet when trying to run the quick start tutorial using the command 'SU2_CFD inv_NACA0012.cfg' I get an error which is depicted in the figure in the link below. https://imgur.com/a/xhqUKTl I have been stuck on this problem for several days now. Please note that I am a beginner to both Linux and SU2 and therefore the solution to this problem might be trivial. My apologies in that case! Any help will be very much appreciated. SOLUTION The name of the .cfg file given in the quick tutorial (inv_NACA0012.cfg) does not correspond to the .cfg file downloaded in the tutorial github section (inv_NACA0012_basic.cfg). Use the right filename solves the problem. Last edited by Sanghera; October 5, 2018 at 06:53. |
su2 installation error |
DPM udf error | haghshenasfard | FLUENT | 0 | April 13, 2016 07:35 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 19:00 |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 10:31 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 07:42 |
Compiling problems with hello worldC | fw407 | OpenFOAM Installation | 21 | January 6, 2008 18:38 |
