Home > Forums > Software User Forums > SU2 > SU2 Installation
icpc: error #10106: Fatal error in intel/2018.2
Old   June 1, 2018, 00:31
Default icpc: error #10106: Fatal error in intel/2018.2
Fatih Ertinaz
fertinaz is on a distinguished road
Hello everyone
Trying to install SU2-6.0.0 on a large cluster using intel/2018.2 and intelmpi/2018.2 however it fails at the step:
  CXX      ../src/libSU2_a-gauss_structure.o
icpc: error #10106: Fatal error in /...../intel/2018.2/compilers_and_libraries_2018.2.199/linux/bin/intel64/mcpcom, terminated by kill signal
compilation aborted for ../src/geometry_structure.cpp (code 1)
make[1]: *** [../src/libSU2_a-geometry_structure.o] Error 1
A very similar error has been explained here:
https://software.intel.com/en-us/for...r/topic/538994
This is how I configure and run make:
cflags="-O2"
cxxflags="-O2"
./configure CFLAGS=$cflags CXXFLAGS=$cxxflags \
  --prefix=$prefix \
  --enable-mpi     \
  --with-cc=${I_MPI_ROOT}/intel64/bin/mpicc   \
  --with-cxx=${I_MPI_ROOT}/intel64/bin/mpicxx
make -j 10 install
Changing optimization flag to -O2 didn't work for me.
Any suggestions much appreciated
EDIT: Reducing optimization to -O1 makes it work fine but I guess it is not the ideal solution. Any ideas?
fertinaz is offline   Reply With Quote
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' muth OpenFOAM Running, Solving & CFD 3 August 27, 2018 05:18
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 19:45
[snappyHexMesh] sHM: FATAL ERROR: More than six unsigned transforms detected Djub OpenFOAM Meshing & Mesh Conversion 0 July 15, 2014 05:43
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 16:16
