Home > Forums > Software User Forums > SU2 > SU2 Installation
SU2 transition modeling
Old   February 21, 2018, 07:53
Default SU2 transition modeling
mike
fluidmechanics is on a distinguished road
Dear All;
I am a new user of SU2 code. I'm going to implement Gamma-Retheta SST transition model in SU2 code. Has anybody done similar development? Where should I start from?
Any help is appreciated.
fluidmechanics is offline   Reply With Quote
Old   February 24, 2018, 14:46
Francisco Palacios
fpalacios is on a distinguished road
Hi Mike,
Welcome aboard! Implementing a transition model it will take some time. My recommendation is to get familiar with the software (e.g. the SA turbulence model) and start from that. There is a transitional method in SU2
https://su2code.github.io/tutorials/...al_Flat_Plate/
you can take a look at the tutorial
Best,
Francisco
if you are interested in developing SU2 maybe SU2 IDS www.su2devsociety.org is interesting for you.
Best,
Francisco
fpalacios is offline   Reply With Quote
Old   March 5, 2018, 00:10
mike
Thanks Francisco.
I have run those available transition case studies. I am going to study pitching airfoil, too. The available cfg files for unsteady cases are transonic flows at Ma=0.7. My problem is incompressible. Since I am a new user, I don't k7now which commands must be change in available transonic cfg pitching foil.
Would you please help me with an incompressible cfg pitching file?
Regards
B-C transition model in SU2 whizkid SU2 2 November 27, 2017 03:03
SU2 LM Transition Model (v4.1.0 cardinal release) whizkid SU2 1 January 26, 2016 05:46
su2 transition point and output settings varghese9 SU2 2 March 5, 2015 13:13
Transition modeling using K-w Athar CFX 1 November 25, 1999 02:40
Transition Modeling using CFX4.2 Athar Main CFD Forum 1 November 24, 1999 16:02
