Home > Forums > Software User Forums > SU2 > SU2 Installation
Lost instructions for installing mingw64
Old   February 16, 2018, 07:58
Default Lost instructions for installing mingw64
Terry L. Coons
tlcoons is on a distinguished road
I was installing mingw64 using the msys2. I closed the browser by mistake and now I can't find the web page with the instructions.
The steps I was following were:
Terry Coons@MSI MINGW64 /
$ printenv | grep "WIN\|MSMPI
> mkdir ~/msmpi
> cd ~/msmpi
> cp "$MSMPI_LIB64/MSMPI.LIB"
> cp "$WINDIR/system32/msmpi.dll"
> gendef msmpi.dll
> dlltool -d msmpi.def -
mkdir ~/msmpi
cd ~/msmpi
gendef msmpi.dll
dlltool -d msmpi.def -D msmpi.dll
grep: Files: No such file or directory
grep: (x86)\Microsoft: No such file or directory
grep: SDKs\MPI\Lib\x64\/MSMPI.LIB
cp C:\WINDOWS/system32/msmpi.dll
gendef msmpi.dll
printenv | grep WIN|MSMPI: No such file or directory
cp: missing destination file operand after 'C:\Program Files (x86)\Microsoft SDKs\MPI\Lib\x64\/MSMPI.LIB'
Try 'cp --help' for more information.
cp: missing destination file operand after 'C:\WINDOWS/system32/msmpi.dll'
-bash: gendef: command not found
-bash: dlltool: command not found
Terry Coons@MSI MINGW64 ~/msmpi
$ cp --help
Usage: cp [OPTION]... [-T] SOURCE DEST
or: cp [OPTION]... SOURCE... DIRECTORY
or: cp [OPTION]... -t DIRECTORY SOURCE...
Copy SOURCE to DEST, or multiple SOURCE(s) to DIRECTORY.
Mandatory arguments to long options are mandatory for short options too.
-a, --archive same as -dR --preserve=all
--attributes-only don't copy the file data, just the attributes
--backup[=CONTROL] make a backup of each existing destination file
-b like --backup but does not accept an argument
--copy-contents copy contents of special files when recursive
-d same as --no-dereference --preserve=links
-f, --force if an existing destination file cannot be
opened, remove it and try again (this option
is ignored when the -n option is also used)
-i, --interactive prompt before overwrite (overrides a previous -n
option)
-H follow command-line symbolic links in SOURCE
-l, --link hard link files instead of copying
-L, --dereference always follow symbolic links in SOURCE
-n, --no-clobber do not overwrite an existing file (overrides
a previous -i option)
-P, --no-dereference never follow symbolic links in SOURCE
-p same as --preserve=mode,ownership,timestamps
--preserve[=ATTR_LIST] preserve the specified attributes (default:
mode,ownership,timestamps), if possible
additional attributes: context, links, xattr,
all
--no-preserve=ATTR_LIST don't preserve the specified attributes
--parents use full source file name under DIRECTORY
-R, -r, --recursive copy directories recursively
--reflink[=WHEN] control clone/CoW copies. See below
--remove-destination remove each existing destination file before
attempting to open it (contrast with --force)
--sparse=WHEN control creation of sparse files. See below
--strip-trailing-slashes remove any trailing slashes from each SOURCE
argument
-s, --symbolic-link make symbolic links instead of copying
-S, --suffix=SUFFIX override the usual backup suffix
-t, --target-directory=DIRECTORY copy all SOURCE arguments into DIRECTORY
-T, --no-target-directory treat DEST as a normal file
-u, --update copy only when the SOURCE file is newer
than the destination file or when the
destination file is missing
-v, --verbose explain what is being done
-x, --one-file-system stay on this file system
-Z set SELinux security context of destination
file to default type
--context[=CTX] like -Z, or if CTX is specified then set the
SELinux or SMACK security context to CTX
--help display this help and exit
--version output version information and exit
By default, sparse SOURCE files are detected by a crude heuristic and the
corresponding DEST file is made sparse as well. That is the behavior
selected by --sparse=auto. Specify --sparse=always to create a sparse DEST
file whenever the SOURCE file contains a long enough sequence of zero bytes.
Use --sparse=never to inhibit creation of sparse files.
When --reflink[=always] is specified, perform a lightweight copy, where the
data blocks are copied only when modified. If this is not possible the copy
fails, or if --reflink=auto is specified, fall back to a standard copy.
The backup suffix is '~', unless set with --suffix or SIMPLE_BACKUP_SUFFIX.
The version control method may be selected via the --backup option or through
the VERSION_CONTROL environment variable. Here are the values:
none, off never make backups (even if --backup is given)
numbered, t make numbered backups
existing, nil numbered if numbered backups exist, simple otherwise
simple, never always make simple backups
As a special case, cp makes a backup of SOURCE when the force and backup
options are given and SOURCE and DEST are the same name for an existing,
regular file.
GNU coreutils online help: <http://www.gnu.org/software/coreutils/>
Full documentation at: <http://www.gnu.org/software/coreutils/cp>
or available locally via: info '(coreutils) cp invocation'
$ cp "$MSMPI_LIB64/MSMPI.LIB" ~/msmpi
$ cp "$WINDIR/system32/msmpi.dll" ~/msmpi
$ gendef msmpi.dll
$ ls
msmpi.dll MSMPI.LIB
$ gendef msmpi.dll
$ gendef msmpi.dll
$ gendef.exe msmpi.dll
-bash: gendef.exe: command not found
$ cp "$WINDIR/Program Files (x86)/mingw-w64/i686-7.2.0-posix-dwarf-rt_v5-rev1/mingw32/bin/gendef.exe ~/msmpi
> ls
> gendef msmpi.dll
> cp libmsmpi.a /mingw64/lib
> cp "MSMPI_INC/mpi.h" .
> cp mpi.h /mingw64/include
ls
gendef msmpi.dll
-bash: syntax error near unexpected token `('
msmpi.dll MSMPI.LIB
cp: cannot stat 'libmsmpi.a': No such file or directory
cp: cannot stat 'MSMPI_INC/mpi.h': No such file or directory
cp: cannot stat 'mpi.h': No such file or directory
$ cd ~
$ mkdir mpi_hello
$ cd mpi_hello
Terry Coons@MSI MINGW64 ~/mpi_hello
Can somebody tell how to find the web page that matches these steps?
tlcoons is offline   Reply With Quote
install mingw64 for su2
Frequently Asked Questions about Installing OpenFOAM wyldckat OpenFOAM Installation 3 November 14, 2023 12:58
Injection injection-0: LOST 2 out of 20 injection locations attaullah FLUENT 17 March 2, 2023 11:31
lost of mass conservation jjchristophe FLUENT 0 June 18, 2010 06:44
lost of mass conversation jjchristophe FLUENT 0 June 17, 2010 09:53
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 19:07
