January 9, 2018, 08:08 |
Error in compiling SU2_AD
Lucia
Rep Power: 9 |
I am trying to use the adjoint in SU2 (branch feature_turbo2phase). I ran the ./preconfigure.py --enable-autodiff, and everything went fine, no errors are displayed. But when I compile it (sudo make install) there is an error in SU2_AD, I took the screenshot of what I get. It looks related to the "externals/codi" folder, so I tried to remove it and re-do all the steps, but I get the same error. Did anyone encounter this problem before? |
January 10, 2018, 19:15 |
Tim Albring
Rep Power: 11 |
Hi Lucia,
it seems like you are using an older version (4.6) of gcc to compile the code. For the AD stuff we need at least version 4.7. I am not really familiar with ubuntu, but I am sure there is a way to update the compiler even in older versions of ubuntu. Perhaps you find some information here. Tim
Developer Director @ SU2 Foundation Get involved:
January 11, 2018, 08:20 |
Lucia
Rep Power: 9 |
Thanks! 4.7 does not work, but 4.9 yes, problem solved
compilation su2_ad |
[OpenFOAM.org] Compiling OpenFOAM 5.0 on the Titan Supercomputer | wildfire230 | OpenFOAM Installation | 20 | May 6, 2020 08:30 |
Getting error both interpreting and compiling | serene6390 | Fluent UDF and Scheme Programming | 1 | October 27, 2017 01:49 |
All files present. but solver not compiling | saddy | OpenFOAM Programming & Development | 1 | July 29, 2017 10:50 |
[OpenFOAM.org] Trouble Compiling OpenFOAM-dev using Intel Compiler 15 for use on Xeon Phi | foamer123 | OpenFOAM Installation | 9 | August 20, 2015 15:03 |
Help with KIVA4 source code compiling | geothokar | Main CFD Forum | 0 | September 3, 2010 06:40 |
