November 24, 2017, 18:38 |
no more CONVERT_TO_METERS option?
Tom Jentink
Rep Power: 13 |
Do I have to scale all my grids to meters before running now?
November 28, 2017, 14:29 |
Tim Albring
Rep Power: 11 |
Hi Tom,
yes, your mesh has to be in meters in current versions of the code. However, you can scale the mesh with SU2_DEF if necessary. In order to do that add the following options to the config file: DV_KIND= SCALE % put ALL the markers that are in your mesh here as a comma separated list DV_MARKER = ( AIRFOIL, FARFIELD ) % this option is ignored, but has to be present DV_PARAM = (1, 0.5) % the factor you want to scale the mesh with DV_VALUE = 1.0 Then simply run SU2_DEF. Unless you haven't changed the filename in the config file, the new mesh will be called "mesh_out.su2". Tim
Developer Director @ SU2 Foundation Get involved:
Question about adaptive timestepping | Guille1811 | CFX | 25 | November 12, 2017 18:38 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 06:15 |
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion | faizan_habib7 | CFX | 4 | February 1, 2016 18:00 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 07:20 |
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
