October 14, 2017, 07:31 |
the mesh files about TestCase
Rep Power: 9 |
When I want to run tutorial cases, I find that these cases don't have corresponding mesh files.
So I read the wiki about SU2 on github, it tells me that runing "python serial_regression.py" will get all of the necessary config and mesh files. But after I did, the terminal shows the message: ==================== Start Test: contadj_euler_py ==================== /mnt/c/Users/dingk/Documents/SU2/TestCases/cont_adj_euler/naca0012 Traceback (most recent call last): File "/mnt/c/Users/dingk/SU2_linux/bin/continuous_adjoint.py", line 159, in <module> main() File "/mnt/c/Users/dingk/SU2_linux/bin/continuous_adjoint.py", line 64, in main options.step ) File "/mnt/c/Users/dingk/SU2_linux/bin/continuous_adjoint.py", line 97, in continuous_adjoint info = SU2.run.direct(config) File "/mnt/c/Users/dingk/SU2_linux/bin/SU2/run/direct.py", line 83, in direct SU2_CFD(konfig) File "/mnt/c/Users/dingk/SU2_linux/bin/SU2/run/interface.py", line 117, in CFD run_command( the_Command ) File "/mnt/c/Users/dingk/SU2_linux/bin/SU2/run/interface.py", line 297, in run_command raise exception , message SU2.EvaluationFailure: Path = /mnt/c/Users/dingk/Documents/SU2/TestCases/cont_adj_euler/naca0012/, Command = /mnt/c/Users/dingk/SU2_linux/bin/SU2_CFD config_CFD.cfg SU2 process returned error '1' application called MPI_Abort(MPI_COMM_WORLD, 1) - process 0 [unset]: write_line error; fd=-1 buf=:cmd=abort exitcode=1 : system msg for write_line failure : Bad file descriptor Traceback (most recent call last): File "serial_regression.py", line 983, in <module> main() File "serial_regression.py", line 861, in main pass_list.append(contadj_euler_py.run_filediff()) File "/mnt/c/Users/dingk/Documents/SU2/TestCases/TestCase.py", line 240, in run_filediff fromdate = time.ctime(os.stat(fromfile).st_mtime) OSError: [Errno 2] No such file or directory: 'of_grad_cd.dat.ref' Could someone help me with a little bit of advice? Thanks! |
October 15, 2017, 05:45 |
Tim Albring
Rep Power: 11 |
Hi Kaizhi,
have a look here: https://github.com/su2code/SU2/wiki/Test-Cases In short: you have to clone or download the TestCases repository which contains all the mesh files since the main repo only contains the config files. Tim
Developer Director @ SU2 Foundation Get involved:
October 15, 2017, 09:49 |
#3 | |
Rep Power: 9 |
I read the wiki and find that the commond "git clone https://github.com/su2code/TestCases.git" will give me the mesh files. |
meshfile, testcases |
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 08:34 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 09:54 |
[Technical] Creating your own mesh files | doug | OpenFOAM Meshing & Mesh Conversion | 28 | April 9, 2009 08:36 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 19:10 |
