May 1, 2017, 11:27 |
Error in Running Python Scripts
I am trying to install SU2 v5.0.0. When I attempt to run python scripts such as shape_optimization.py I get the following error: stebbt@stebbt-VirtualBox:~/su2_o/bin$ shape_optimization.py -f inv_ONERAM6_adv.cfg Traceback (most recent call last): File "/usr/local/bin/shape_optimization.py", line 36, in <module> sys.path.append(os.environ['SU2_RUN']) File "/usr/lib/python2.7/UserDict.py", line 40, in __getitem__ raise KeyError(key) KeyError: 'SU2_RUN' I configured using: ./configure --prefix=/home/stebbt/su2_o CXXFLAGS="-O3" --enable-mpi --with-cc=/home/stebbt/mpi_install/bin/mpicc --with-cxx=/home/stebbt/mpi_install/bin/mpicxx --enable-PY_WRAPPER and set my environment variables in /.bashrc: export SU2_RUN="/home/stebbt/su2_opt/bin" export SU2_HOME="/home/stebbt/SU2" export PATH=$PATH:$SU2_RUN export PYTHONPATH=$PYTHONPATH:$SU2_RUN I am new to Linux so I am not sure if I have the paths set correctly. Any help would be greatly appreciated! EDIT: I tried exporting the paths directly in the terminal command line and it seemed to correct the issue, I can now run the python scripts. I know this is more of a linux question, but does that mean /.bashrc is not being read/used when using my terminal? Last edited by stebbt; May 1, 2017 at 12:06. Reason: /.bashrc not being read by terminal |
May 4, 2017, 05:01 |
Tim Albring
Rep Power: 10 |
You should add these lines to the file ~/.bashrc not /.bashrc (maybe it is just a typo though). Furthermore you install SU2 to /home/stebbt/su2_o but SU2_RUN points to /home/stebbt/su2_opt/bin
python script error, su2_run error |
[OpenFOAM.org] Error running #codeStream/functions wmake lnInclude fails to open *.H Files | tarik | OpenFOAM Installation | 8 | June 14, 2020 03:12 |
[foam-extend.org] Foam Extend 3.2 in ubuntu 16.04 LTS | JMosiezny | OpenFOAM Installation | 15 | December 9, 2017 08:20 |
OpenFOAM parallel on VM? pimpleDyMFoam propeller tutorial has been running for hours. | MBttR | OpenFOAM Running, Solving & CFD | 0 | June 13, 2016 10:58 |
Hypersonic Sim (running at Mach 7): floating point exception has occurred | bungusbeefcake | STAR-CCM+ | 10 | March 31, 2015 06:59 |
Fluent 14.0 file not running in parallel mode in cluster | tejakalva | FLUENT | 0 | February 4, 2015 07:02 |
