Home > Forums > Software User Forums > SU2 > SU2 Installation
Error AD build of SU2-5.0.0 on a HPC system
Old   April 5, 2017, 22:57
Default Error AD build of SU2-5.0.0 on a HPC system
WANG,Hao
Haowang is on a distinguished road
Hi everyone,
I am trying to build Raven master (V5.0) with AD support using preconfigure.py. Since the HPC system can't access the internet, I have download and decompress the codi and adjointmpi packages before configuration.
My command is this:
export CXXFLAGS="-O3 -Wall" && ./preconfigure.py --enable-autodiff --enable-mpi --prefix=/vol6/home/zhhan/wh/SU25SOURCE
And received this error:
Checking the status of submodules
.gitmodules not found, using fall-back method...
Found correct version of CoDiPack in externals/codi.
Found correct version of AdjointMPI in externals/adjointmpi.
Configuring and building AdjointMPI in externals/adjointmpi
Command: ./configure --prefix=/vol6/home/zhhan/wh/SU25SOURCE/externals/adjointmpi && make clean && make
There was an error while running command './configure --prefix=/vol6/home/zhhan/wh/SU25SOURCE/externals/adjointmpi && make clean && make'.
=== Error Log ===
/bin/sh: ./configure: No such file or directory
Now I have solved this problem by copy these file from my own PC which has built SU2 using AD build. But the cluster reported other errors:
CXX ../src/libSU2_AD_a-config_structure.o
CXX ../src/libSU2_AD_a-dual_grid_structure.o
CXX ../src/libSU2_AD_a-geometry_structure.o
CXX ../src/libSU2_AD_a-grid_adaptation_structure.o
CXX ../src/libSU2_AD_a-grid_movement_structure.o
CXX ../src/libSU2_AD_a-linear_solvers_structure.o
CXX ../src/libSU2_AD_a-primal_grid_structure.o
CXX ../src/libSU2_AD_a-vector_structure.o
CXX ../src/libSU2_AD_a-matrix_structure.o
CXX ../src/libSU2_AD_a-mpi_structure.o
CXX ../src/libSU2_AD_a-linear_solvers_structure_b.o
on or static data member
alueType>{
here after previous syntax error
../../../externals/codi/include/tapes/forwardEvaluation.hpp(244): error: expected a ";"
../../../externals/codi/include/tapes/forwardEvaluation.hpp(245): error: expected a declaration
alueType>{
alueType>{
alueType>{
alueType>{
/usr/include/c++/4.4.7/iomanip(92): error: identifier "_Setiosflags" is undefined
inline _Setiosflags
ame
setiosflags(ios_base::fmtflags __mask)
ly
inline _Setiosflags
/usr/include/c++/4.4.7/iomanip(93): error: expected a ")"
The complete log file is in the attachment.
Thank you!
Haowang is offline   Reply With Quote
Old   April 12, 2017, 05:11
Tim Albring
talbring is on a distinguished road
Hi Hao,
with the last major release, the minimum compiler versions for the AD build are now GCC >= v4.7, Clang >= v3.0 or Intel C++ >= v12.0 because we need C++11 features. It looks like you are using GCC 4.4.7 which is not supported anymore ...
Tim
talbring is offline   Reply With Quote
Old   April 13, 2017, 01:12
WANG,Hao
Originally Posted by talbring View Post
Hi Hao,
Tim
Thanks Tim! I have noticed that requirement. However i was actually using intel2013-mpi3.0.4 to build SU2-5.0.0. I have no idea why it used the lib from gcc4.4. I guess it is because the wrong LD_LIBRARY_PATH. Here is my LD_LIBRARY_PATH:
/vol6/software/python-2.7.11/lib:/vol6/software/mpi/mpi-intel2013/lib:
The attachment is the config.log in the SU2_AD folder. I hope someone couldhelp me to find some clue. By the way, i've build the SU2 in parallel build model successfully on the same HPC system.
Thanks again!
Old   April 30, 2017, 12:22
WANG,Hao
Thanks again!
I have find out the reason. It is indeed the problem of the version of the GCC. I upgraded the GCC compiler and mpich2, then i build SU2 in AD Build successfully.
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 19:56
Need ideas-fuel discharge system Jan FLUENT 1 October 11, 2006 00:05
Need ideas-fuel discharge system Jan CFX 1 October 9, 2006 09:16
Need ideas-fuel delivery system Jan Fidelity CFD 0 October 9, 2006 05:30
Need ideas-fuel discharge system Jan Main CFD Forum 0 October 9, 2006 05:27
