January 21, 2017, 13:47 |
Failed configuration with AD support
Eran Arad
Rep Power: 11 |
Hi
Tried to build Raven master (V5.0) with AD support using preconfigure.py. Received errors on setting locations of libraries like --with-Jsoncpp-lib= ... --with-CGNS-include= ... and so forth. Any suggestion how to do that ? Thanks Eran |
February 1, 2017, 12:09 |
Tim Albring
Rep Power: 11 |
Hi Eran,
the options --with-Jsoncpp-lib= ... --with-CGNS-include= ... are not needed anymore. So you can simply drop them. Tim |
February 1, 2017, 15:28 |
Eran Arad
Rep Power: 11 |
Thanks Tim
Seems to work well till the make install: I tried to set also --enable-PY_WRAPPER . Worked OK with the preconfigure and make. However, make install tried : /usr/bin/install -c pysu2.py [SU2-dir]/bin from [install dir]/SU2_AD/SU2_PY/pySU2 but this folder contained only a makefile and nothing else so error occurred. Is it required to avoid python wrapper when compiling with AD ? Thanks Eran |
Foam::error::printStack(Foam::Ostream&) with simpleFoam -parallel | U.Golling | OpenFOAM Running, Solving & CFD | 52 | September 23, 2023 04:35 |
Initial conditions for uniform flow | andreas | OpenFOAM | 5 | November 16, 2012 16:00 |
[OpenFOAM] ParaView/Parafoam error when making animation | Disco_Caine | ParaView | 6 | September 28, 2010 10:54 |
user subroutine error | CFDUSER | CFX | 2 | December 9, 2006 07:31 |
user defined function | cfduser | CFX | 0 | April 29, 2006 11:58 |
