Home > Forums > Software User Forums > SU2 > SU2 Installation
Cannot run with the new release v4.3
Old   August 25, 2016, 05:58
Default Cannot run with the new release v4.3
Paul Zhang
paulzhang is on a distinguished road
The same configurations are used to compile
./configure CXXFLAGS="-O3" --enable-mpi --with-cc=/usr/local/mpi3-dynamic/bin/mpicc --with-cxx=/usr/local/mpi3-dynamic/bin/mpicxx
CGNS flag is no need to enable since the new version has already taken care of it.
The older version compiled using the same flags, working without any problem. But when it came to the v4.3, a couple of issues when ran the quicktest,
1. segmentation fault after the Begin Solver.
2. when using multi-cores, got multi-thread outputs. Must be something wrong with the mpi.
Does anybody else have a similar issue? Or it is just my problem.
Thanks,
Paul
paulzhang is offline   Reply With Quote
Old   August 29, 2016, 00:13
Default Issue solved
Paul Zhang
Guess there is something weird with my make.
1. If my initial compile using single processor $make -j 1 all, it is workable. Otherwise the compiled binary fails to use multi-processors in the run. It always take it serial.
2. However, once compiled successfully, my later compile can always use $make -j 8, and I do not see any problem.
"You gotta be kidding me". That's what she said.
Release of foam-extend-3.0 hjasak OpenFOAM Announcements from Other Sources 2 September 21, 2014 08:08
[mesh manipulation] Cannot get refineMesh to run in parallel smschnob OpenFOAM Meshing & Mesh Conversion 2 June 3, 2014 12:20
Memory release after killing the run nisha OpenFOAM Running, Solving & CFD 4 November 27, 2013 07:17
Extend Project Release 1.6-ext hjasak OpenFOAM Announcements from Other Sources 33 July 14, 2011 19:54
Diesel combustion simulation ( Heat release rate) venkatesh Siemens 2 April 29, 2009 08:38
