May 11, 2016, 10:27 |
Parallel SU2 v3.2.2 do not work
Andrei
What's wrong?
Program (direct computation) is terminated with follows: ------------------------ Physical case definition ----------------------- ------------------------ Physical case definition ----------------------- Input mesh file name: mesh_SC2-0412v4.su2 Input mesh file name: mesh_SC2-0412v4.su2 -------------------------- Output information --------------------------- -------------------------- Output information --------------------------- Don't visualize the partitions. Don't visualize the partitions. ------------------- Config file boundary information -------------------- ------------------- Config file boundary information -------------------- Far-field boundary marker(s): FARBND. Far-field boundary marker(s): FARBND. Constant heat flux wall boundary marker(s): PROFILE. Constant heat flux wall boundary marker(s): PROFILE. ---------------------- Read grid file information ----------------------- Two dimensional problem. 35100 interior elements. 645 triangles. 34455 quadrilaterals. 35043 points. 2 surface markers. 419 boundary elements in index 0 (Marker = PROFILE). 112 boundary elements in index 1 (Marker = FARBND). ------------------------ Divide the numerical grid ---------------------- ----------------------------- Write mesh files -------------------------- job aborted: [ranks] message [0] terminated [1] process exited without calling finalize ---- error analysis ----- [1] on Server09 C:\SU2\SU2_DDC ended prematurely and may have crashed. exit code 0xc0000005 ---- error analysis ----- SU2 process was terminated by signal '3' |
August 16, 2016, 18:53 |
Heather Kline
Rep Power: 14 |
SU2 optimization does not work correctly with CGNS format | Andrei | SU2 Shape Design | 1 | April 22, 2016 10:35 |
parallel efficiency in SU2 | ymc11 | SU2 | 2 | January 6, 2016 20:41 |
First order in fvSchemes does not seem to work | gerritgroot | OpenFOAM Running, Solving & CFD | 0 | September 30, 2015 20:06 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 18:45 |
SU2 parallel running error,help~~~ | nuaawubin | SU2 Installation | 5 | January 30, 2014 17:18 |
