Home > Forums > Software User Forums > SU2 > SU2 Installation
Where to find parallel v4.0 for Windows?
Old   August 19, 2015, 12:11
Default Where to find parallel v4.0 for Windows?
aberkk is on a distinguished road
I have downloaded a parallel version for the Windows installer in the past (v3 Eagle) and I can't seem to find it for v4 Cardinal. Is there parallel version available yet? I have successfully installed and ran the single threaded version. The installation instructions located in the Guides seem to indicate that it may just be a setting change. Is this true? Please advise.
Thanks!
aberkk is offline   Reply With Quote
Old   September 15, 2015, 17:31
hlk
Heather Kline
hlk is on a distinguished road
Thanks!
As with the binaries for Linux and Mac, the pre-compiled versions are only provided for serial.
In order to install with parallel, you will need to install from the source code, as this requires interaction with the particular system. On windows this also requires downloading additional packages (see https://github.com/su2code/SU2/wiki/...s-Installation)
Many users find it easier to use a linux partition (or virtual machine) for running in parallel.
hlk is offline   Reply With Quote
cardinal, parallel installation, windows
OpenFoam parallel on 2 computers : Cannot find file "points" Blue8655 OpenFOAM Running, Solving & CFD 1 June 3, 2015 22:59
[foam-extend.org] Installing foam-extend 3.1 on Ubuntu 14.04 stephie OpenFOAM Installation 16 April 23, 2015 17:18
simpleFoam in parallel issue plucas OpenFOAM Running, Solving & CFD 3 July 17, 2013 12:30
Cyclic patch in parallel calculations didomenico OpenFOAM Running, Solving & CFD 4 March 7, 2007 06:46
Parallel solver with 3.2 robbie Siemens 1 August 10, 2004 08:29
