Home > Forums > Software User Forums > SU2 > SU2 Installation
Installing SU2 on Linux
Old   July 30, 2015, 08:24
Default Installing SU2 on Linux
Antonio Lattanziu
tonino is on a distinguished road
Hi guys when I execute the following commands in a terminal:
cd /path/to/your/SU2/ ./configure
the results is:
Please be sure to add the $SU2_HOME and $SU2_RUN environment variables,
and update your $PATH (and $PYTHONPATH if applicable) with $SU2_RUN.
Based on the input to this configuration, add these lines to your .bashrc file:
export SU2_RUN="/usr/local/bin"
export SU2_HOME="/home/antonio/Scrivania/SU2"
export PATH=$PATH:$SU2_RUN
export PYTHONPATH=$PYTHONPATH:$SU2_RUN
how do I edit the file .bashrc if you can not find it?
Thanks
tonino is offline   Reply With Quote
Old   August 8, 2015, 17:33
hlk
Heather Kline
hlk is on a distinguished road
the results is:
Thanks
The .bashcr file, and in general all .files will not be visible with the ls command or file explorers, as these files are hidden. By default this file will be in your home (
~/) directory, and should be visible if you use
ls -a ~/
Please note that this assumes you are using bash shell. The .bashrc script is run every time a bash shell is openned, and after you edit in in order to use the new aliases without starting a new terminal you should run
source ~/.bashrc
hlk is offline   Reply With Quote
[Helyx OS] Installing HelyxOS on 32 and 64bit Linux Distributions wyldckat OpenFOAM Community Contributions 16 December 23, 2016 07:37
LINUX Experts: Help with installing ANSYS workbench faisal_durr ANSYS 1 May 30, 2014 09:07
Dual Boot Windows and Linux and Go Open Source andyj Main CFD Forum 2 October 21, 2010 17:49
My experience Installing Elmer (Open Source Multi physics programme) on Linux Ahmed Main CFD Forum 3 August 10, 2010 14:42
why i get this error during installing Linux Fedora? gholamghar Main CFD Forum 1 July 23, 2010 04:14
