Home > Forums > Software User Forums > SU2 > SU2 Installation
Using Anaconda python under cygwin for SU2
Old   July 5, 2015, 05:39
Default Using Anaconda python under cygwin for SU2
NG YIN CHEANG
Kelvin Ng is on a distinguished road
Hi all,
I am trying to do some optimization with SU2 because of the difficulty of Scipy installation i use anaconda python as cygwin default python . However , when i try to run a optimization case , cygwin window show
C:\cygwin64\usr\Anaconda\python.exe: can't open file '/usr/local/bin/shape_optimization.py': [Errno 2] No such file or directory
anyone have ideal to fix this ?
Thank you.
Best Regards
Kelvin Ng is offline   Reply With Quote
Old   July 23, 2015, 19:27
hlk
Heather Kline
hlk is on a distinguished road
Originally Posted by Kelvin Ng View Post
Hi all,
Thank you.
Best Regards
Is shape_optimization.py in /usr/local/bin?
If not, find where it is and update the path (see installation instructions on github wiki)
If it is, and cygwin does not have permission to access or something else, you can try installing to a directory that cygwin can access. You probably already did this, but since the compiled version is platform-dependent and cygwin emulates linux, it would be the linux/installed from source version that you need to be able to run in cygwin.
hlk is offline   Reply With Quote
su2 error
[OpenFOAM] using the python shell in paraFoam colinB ParaView 14 September 14, 2015 10:04
[OpenFOAM] paraview v4 - building with python - OF2.3.0, PVv4, Python 2.7 aylalisa ParaView 4 June 13, 2014 09:52
How to get Python Shell into ParaView 3.8.1? blaise OpenFOAM Installation 3 July 24, 2012 05:58
CentFOAM Python Script Installation: Error socon009 OpenFOAM Installation 2 May 26, 2012 10:36
Fieldview 11.1 + Python to extract 3D core of data Rebecca FieldView 0 April 13, 2011 14:06
