Home > Forums > Software User Forums > SU2 > SU2 Installation
Errors when attempt to run parallel computation
Old   March 19, 2015, 10:29
Default Errors when attempt to run parallel computation
Yan Bochao
wruudf is on a distinguished road
Again, the serial computation is always good. But errors happens to come out with MPI. Below is the error:
mpirun noticed that process rank 1 with PID 56732 on node yan-virtual-machine exited on signal 11 (Segmentation fault).
Traceback (most recent call last):
File "/home/yan/Downloads/su2/bin/parallel_computation.py", line 110, in <module>
main()
File "/home/yan/Downloads/su2/bin/parallel_computation.py", line 61, in main
options.compute )
File "/home/yan/Downloads/su2/bin/parallel_computation.py", line 88, in parallel_computation
info = SU2.run.CFD(config)
File "/home/yan/Downloads/su2/bin/SU2/run/interface.py", line 88, in CFD
run_command( the_Command )
File "/home/yan/Downloads/su2/bin/SU2/run/interface.py", line 276, in run_command
raise exception , message
RuntimeError: Path = /home/yan/Downloads/su2/bin/,
Command = mpirun -n 2 /home/yan/Downloads/su2/bin/SU2_CFD config_CFD.cfg
SU2 process returned error '139'
[yan-virtual-machine:56732] *** Process received signal ***
[yan-virtual-machine:56732] Signal: Segmentation fault (11)
[yan-virtual-machine:56732] Signal code: Address not mapped (1)
[yan-virtual-machine:56732] Failing at address: 0xf4
[yan-virtual-machine:56732] [ 0] /lib/x86_64-linux-gnu/libpthread.so.0(+0x10340)[0x7f2b99b93340]
[yan-virtual-machine:56732] [ 1] /home/yan/Downloads/su2/bin/SU2_CFD[0x87c94e]
[yan-virtual-machine:56732] [ 2] /home/yan/Downloads/su2/bin/SU2_CFD[0x5b1b89]
[yan-virtual-machine:56732] [ 3] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf5)[0x7f2b997dfec5]
[yan-virtual-machine:56732] [ 4] /home/yan/Downloads/su2/bin/SU2_CFD[0x69218b]
[yan-virtual-machine:56732] *** End of error message ***
wruudf is offline   Reply With Quote
Old   May 12, 2015, 17:54
David Manosalvas-Kjono
demanosalvas is on a distinguished road
wruudf,
Can you make sure that the code has been compiled correctly with mpi? for a guide on how to do this, please go to: https://github.com/su2code/SU2/wiki/Build-from-Source
Cheers,
David
demanosalvas is offline   Reply With Quote
[mesh manipulation] Cannot get refineMesh to run in parallel smschnob OpenFOAM Meshing & Mesh Conversion 2 June 3, 2014 12:20
SnappyHexMesh OF-1.6-ext crashes on a parallel run norman1981 OpenFOAM Bugs 5 December 7, 2011 13:48
poor performance at massive parallel run using SGI cluster matthias OpenFOAM Running, Solving & CFD 8 October 21, 2011 09:24
'Finalising parallel run' errors lordvon OpenFOAM 1 October 30, 2010 07:56
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
