Home > Forums > Software User Forums > SU2 > SU2 Installation
SU2 shape_optimization.py parallel run using pbspro job scheduler
Old   January 27, 2015, 01:56
Smile SU2 shape_optimization.py parallel run using pbspro job scheduler
Amit Kamboj
amitkamboj is on a distinguished road
Hi!
I need to run shape_optimization.py on cluster using pbspro job scheduler.
I am interested in running the SU2 problem in parallel. For a flow solving problem using SU2_CFD, I am able to do using the following pbspro script file,
(# indicates the comments, #PBS are read by pbspro)
#! /bin/csh
#######PBS -l walltime=48:00:00
#PBS -N nca6
#PBS -q workq
#PBS -l select=1:ncpus=2:mpiprocs=2
#PBS -l place=scatter:excl
#PBS -V
# Go to the directory from which you submitted the job
# to split the domain
# mpirun -n 2 /local/bin/SU2_PRT inv_NACA0012.cfg
cd $PBS_O_WORKDIR
cat $PBS_NODEFILE > pbsnodes
mpirun --machinefile pbsnodes -n 02 /local/bin/SU2_CFD inv_NACA0012.cfg > /dev/null
# finally..
# scp restart_flow.dat solution_flow.dat
# SU2_SOL inv_NACA0012.cfg
Also, I am able to run the shape_optimization.py through,
shape_optimization.py -f rotating_NACA0012.cfg -n 4
The process works perfectly fine. But when the problem size increases I need to submit the job on more than 1 node using the scheduler, which I am not able to do.
So I want to create a similar script file so that I can submit shape_optimization.py on cluster. Which I am not able to do and need help with.
Would be grateful for any help you can provide.
Thanks in Advance!
amitkamboj is offline   Reply With Quote
Old   May 19, 2015, 17:35
hlk
Heather Kline
hlk is on a distinguished road
Originally Posted by amitkamboj View Post
Hi!
#! /bin/csh
#PBS -N nca6
#PBS -q workq
#PBS -V
cd $PBS_O_WORKDIR
# finally..
Thanks in Advance!
Thanks for your question.
I think this thread includes a lot of notes on using PBS with SU2
http://www.cfd-online.com/Forums/su2...using-pbs.html
hlk is offline   Reply With Quote
Old   May 19, 2015, 19:06
Thomas D. Economon
economon is on a distinguished road
I might also add that you can directly modify the command line call for parallel runs (to add machine files or change the mpiexec call directly) in the file interface.py that will be located in the $YOUR_SU2_INSTALL/SU2/run/ directory.
Hope this helps,
Tom
economon is offline   Reply With Quote
mpirun, best parameters pablodecastillo Hardware 18 November 10, 2016 13:36
Case running in serial, but Parallel run gives error atmcfd OpenFOAM Running, Solving & CFD 18 March 26, 2016 13:40
parallel computation with SU2 V3.2 454514566@qq.com SU2 1 June 24, 2014 21:46
Problem on Parallel Run Setup Hamidur Rahman CFX 0 September 23, 2007 18:11
Windows 64-bit, Distributed Parallel Run Issues... Erich CFX 3 March 28, 2006 17:36
