September 21, 2014, 13:29 |
can't run SU2 CFD.exe in mac OS
emon yaya
i have followed the installation guidance. But I still cant run "su2_cfd inv_NACA0012.cfg"--> command not found or when I double click su2 cfd.exe--> No configuration file. how to solve this?
Thanks |
September 22, 2014, 08:14 |
Khiem Pham
Rep Power: 12 |
You should type SU2_CFD rather than su2_cfd.
Hope this help. |
September 25, 2014, 22:16 |
same for me, no configuration file with the download,
October 9, 2014, 04:00 |
Aulia Maharani Akbar
Rep Power: 12 |
For mac, you should type ./SU2_CFD inv_NACA0012.cfg (or other test case) in the terminal to run the configuration file. Note the ./ command!
parallel run is slower than serial run (pimpleFoam) !!! | mechy | OpenFOAM | 18 | August 17, 2016 17:19 |
Extend Project 1.6-ext Binary Release for Mac OS X | hjasak | OpenFOAM Announcements from Other Sources | 26 | November 5, 2013 16:50 |
Incorrect calculation of forces/moments coefficients with older versions of SU2 | diwakaranant | SU2 | 2 | August 16, 2013 04:17 |
SU2 suite has moved to GitHub! | fpalacios | SU2 News & Announcements | 0 | August 12, 2013 02:07 |
Welcome to the Stanford University Unstructured (SU2) forum! | economon | SU2 | 0 | January 7, 2013 02:48 |
