Home > Forums > Software User Forums > SU2 > SU2 Installation
parallel vs single
Old   June 20, 2014, 12:14
Default parallel vs single
Hedley
hedley is on a distinguished road
Finally got parallel to run BUT where solving on the turb_ONERA6.cfg if I run on single core it runs TWICE as fast as on a four core ??
When running four core it seems to do the same job over on each core + all of the MPI overhead.
hedley is offline   Reply With Quote
Old   June 20, 2014, 12:30
XingYu
454514566@qq.com is on a distinguished road
Do you can run parallel in win7?
If yes,you can tell me how to install the su2 v3.2 in win7,thank you greatly.
454514566@qq.com is offline   Reply With Quote
Old   June 20, 2014, 12:33
Hedley
No I gave up on that . To get it to run on Linux was more a matter of setting up the PATH's to the MPI /bin file . I still think although it runs it is not doing it properly as it is way slower than on one core. The Linux attempt is just a sanity test and once done will try and get windows working
Old   June 23, 2014, 06:19
Jeffrey van Oostrom
Doriris is on a distinguished road
It seems that each calculation is carried out 4 times on 4 cores, rather than 1 time on 4 cores. This is due to a faulty mpicxx setup. View this thread for more info:
http://www.cfd-online.com/Forums/su2...t-4-times.html
The same issue arised on my machine, I simply had to check if the link towards mpicxx was set correctly.
Doriris is offline   Reply With Quote
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 19:45
parallel Grief: BoundaryFields ok in single CPU but NOT in Parallel JR22 OpenFOAM Running, Solving & CFD 2 April 19, 2013 17:49
Error swithcing between single e parallel version of fluent bishop_house FLUENT 0 February 28, 2011 13:14
Parallel Processing of unsteady, structured single block c-grid drrbradford Fidelity CFD 0 April 22, 2010 12:15
P4 1.5 or Dual P3 800EB on Gibabyte board Danial FLUENT 4 September 12, 2001 12:44
