May 28, 2014, 21:26 |
SU2 Compile Error
Rep Power: 12 |
Good Afternoon,
I am running SU2_CFD and I have an error compiling some of the source files. When I edit the c++ files in the Common -> src folder, and then run the "make" and "make install" commands, these files update correctly. However, when I edit the source files located in the bin -> src folder, these files do not compile when I "make" and "make install." Is there any way I can fix this issue and have the program compile all of the source files every time? I am looking to implement a body force on an airfoil, so I need to be able to edit the solver c++ files. Please advise. Thank you, Chris |
June 5, 2014, 14:40 |
Brendan Tracey
Rep Power: 13 |
I do not understand what you mean by "bin -> src" folder. The SU2/bin folder has no "src" subfolder (https://github.com/su2code/SU2/tree/master/bin). Perhaps try rerunning config before make?
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 13:21 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) | Yogini | Fluent UDF and Scheme Programming | 7 | October 3, 2012 07:24 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
