Home > Forums > Software User Forums > SU2 > SU2 Installation
mesh generation with pointwise
Old   May 13, 2014, 04:34
Default mesh generation with pointwise
granbycools is on a distinguished road
Hello everbody
I am about to create my first pointwise mesh for su2 and I am wondering if anybody has any experience with setting the markers for the flow solver within pointwise?
I am talking about the Euler-, farfield wall boundary marker(s) etc?
I appreciate any advice
Best regards
granbycools is offline   Reply With Quote
Old   May 15, 2014, 16:46
aniketaranake is on a distinguished road
Originally Posted by granbycools View Post
Hello everbody
Best regards
Dear granbycools,
In pointwise, first use the menu CAE>Select Solver..., and from the options on the left select Stanford ADL/SU2.
Next, go to CAE>Set Dimension and select whether your case is 2D or 3D.
Finally, go to CAE>Set Boundary Condition. In the panel on the left, create a new boundary and give it a name, for example "farfield." In the main pain, select the edges or faces you wish to describe. Then click the check box to the left of the new boundary condition created in the left pane. Do this for every type of boundary in your case.
When you are done, use File>Export>CAE to save a .su2 grid file.
Be sure to update your case's input file (.cfg) so that the marker names are the same as those you've defined in Pointwise.
Hope this helps!
Aniket
aniketaranake is offline   Reply With Quote
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
Pointwise Mesh Generation to COMSOL lbarkett Mesh Generation & Pre-Processing 1 November 13, 2013 11:22
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
Mesh for a tube with a deflector - Pointwise stone123 Pointwise & Gridgen 1 November 20, 2011 15:14
General questions on grid-based computing Adrin Gharakhani Main CFD Forum 21 June 5, 2000 14:47
