April 10, 2014, 09:33 |
SU2_DDC ended prematurely
Yonatan Afework Tesfahunegn
Rep Power: 13 |
Hi all,
I am trying to run SU2 in parallel in Windows 7, so far I am not successful. I installed HPC Pack 2012 R2 MS-MPI Redistributable Package and tested it with example. The example is executed without any problem. After the test I tried to run SU2_DDC with out using parallel_computation.py, with the following command: mpiexec -n 2 SU2_DDC inv_ONERAM6.cfg Then I got an error saying that SU2_DDC ended prematurely and may have crashed. exit code 0xc0000005 I have also attached the snap shot of the error. Any suggestion for this problem? It would be great if someone could give me any advice on how to setup su2 parallel simulation in windows 7. Thanks for the help. Yona |
May 10, 2014, 16:41 |
I'm getting the same problem, further inspecting the issue it seems SU2_DDC is not able to correctly split the .su2 file and exists prematurely.
For example: Running Code:
parallel_computation -f config_template.cfg -p 2 However, opening them reveals the following content: mesh_NACA0012_inv_1.su2: Code:
NDIME= 0 NELEM= 0 NPOIN= 0 0 NMARK= 0 NPERIODIC= 1 PERIODIC_INDEX= 0 0 0 0 0 0 0 0 0 0 FFD_NBOX= 0 FFD_NLEVEL= 11825 Code:
NDIME= 26991 NELEM= 0 NPOIN= 0 0 NMARK= 0 NPERIODIC= 0 FFD_NBOX= 0 FFD_NLEVEL= 8236 |
May 22, 2014, 22:07 |
#3 | |
XingYu
Rep Power: 12 |
Mesh conversion exits prematurely (Salome to OF) | DMcP | OpenFOAM | 1 | May 16, 2024 10:35 |
simple 2d open ended cylinder with moving piston: dynamic meshing query | lmarf88 | ANSYS | 0 | January 6, 2014 10:55 |
simple open ended pipe flow with moving piston | lmarf88 | ANSYS | 1 | November 22, 2013 22:12 |
[ICEM] prism terminated prematurely in ICEM meshing | yuhehuan | ANSYS Meshing & Geometry | 7 | October 11, 2012 03:19 |
ICEM CFD- Error: prism terminated prematurely | user0314 | ANSYS Meshing & Geometry | 9 | September 20, 2011 14:21 |
