Home > Forums > Software User Forums > SU2 > SU2 Installation
error 262144 and unexpected disconnect when run on 2 nodes
Old   April 9, 2014, 12:13
Default error 262144 and unexpected disconnect when run on 2 nodes
emily
Emily1412 is on a distinguished road
Dear developer,
I tried to run Tutorial 2 on 2 nodes (parallel run of course), and the following errors occurred. I desperately need your help!
This is what it echoed:
raise Exception , message
Exception: Path = /home/SU2-master/TestCases/TestCases/euler/oneram6/,
Command = mpirun -np 32 -host node01,node02 /usr/local/bin/SU2_CFD config_CFD.cfg
SU2 process returned error '1'
[3] rtc_invalidate error 262144
Assertion failed in file ../../i_rtc_hook.c at line 207: 0
internal ABORT - process 3
[5] rtc_invalidate error 262144
internal ABORT - process 5
[7] rtc_invalidate error 262144
internal ABORT - process 7
[9] rtc_invalidate error 262144
internal ABORT - process 9
[11] rtc_invalidate error 262144
internal ABORT - process 11
[13] rtc_invalidate error 262144
internal ABORT - process 13
[25] rtc_invalidate error 262144
internal ABORT - process 25
[2:node01] unexpected disconnect completion event from [5:node02]
Assertion failed in file ../../dapl_conn_rc.c at line 1054: 0
[4:node01] unexpected disconnect completion event from [5:node02]
internal ABORT - process 4
[12:node01] unexpected disconnect completion event from [13:node02]
internal ABORT - process 12
[22:node01] unexpected disconnect completion event from [23:node02]
internal ABORT - process 22
[6:node01] unexpected disconnect completion event from [5:node02]
internal ABORT - process 6
[18:node01] unexpected disconnect completion event from [19:node02]
internal ABORT - process 28
[30:node01] unexpected disconnect completion event from [9:node02]
internal ABORT - process 30
[15:node02] unexpected disconnect completion event from [12:node01]
internal ABORT - process 15
[27:node02] unexpected disconnect completion event from [12:node01]
[29:node02] unexpected disconnect completion event from [12:node01]
internal ABORT - process 29
internal ABORT - process 27
[31:node02] unexpected disconnect completion event from [12:node01]
internal ABORT - process 31
[1:node02] unexpected disconnect completion event from [12:node01]
Emily1412 is offline   Reply With Quote
Old   April 10, 2014, 18:08
Thomas D. Economon
economon is on a distinguished road
Which compiler/MPI are you using to build the code? Does the same issue happen if you try to call SU2_DDC directly without Python, i.e., mpirun -np 32 SU2_DDC your_config.cfg?
economon is offline   Reply With Quote
ANSYS Workbench on "Uncertified" Linux Distros hsr CFX 289 April 20, 2023 10:23
FLUENT installation on UBUNTU 12.04 (LTS) teymourj FLUENT 2 March 1, 2017 23:24
