January 26, 2014, 06:48 |
Su2 ver.3 parallel
James
Rep Power: 13 |
Dear All;
I have two systems, each of them with AMD 8 cores and 16 Gig Ram. How can I run a cfd simulation using SU2 ver.3 on both of them? I mean to run a parallel job using both PCs (partitioning on 16 cores and using 32 gig ram). Thanks a lot |
February 12, 2014, 12:37 |
Thomas D. Economon
Rep Power: 14 |
Hi James,
This type of cluster built from commodity hardware is often called a 'beowulf' cluster. You might look into some references on the necessary hardware and software needed for this (local network, MPI, etc.). Sounds like fun to me.. best of luck, Tom |
SU2 Parallel Computation problem | Gramanzini | SU2 | 5 | September 29, 2018 12:32 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 18:45 |
SU2 parallel installation error | JAlbert | SU2 Installation | 2 | November 19, 2013 02:43 |
SU2 Installation: Parallel version along with Serial | bruzerravi | SU2 Installation | 2 | May 5, 2013 01:22 |
Parallel SU2 | samiam1000 | SU2 | 5 | February 16, 2013 00:41 |
