Home > Forums > Software User Forums > SU2 > SU2 Installation
SU2 v3 installation - tecio.dll missing
Like Tree1Likes
Old   March 20, 2014, 11:40
denzell
denzell is on a distinguished road
Hi all,
Same problem here. I'm running on 32 bit, hence I can not download or use the Tecplot trial.
Did anyone find a workaround?>
denzell is offline   Reply With Quote
Old   March 24, 2014, 05:25
Smile
  #22
yangyang
tangshimingyue is on a distinguished road
Originally Posted by Daniel C.B. View Post
I have been following this thread and the steps provided. I have installed the Tecplot 360 but when I run the 'SU2_CFD.exe' a black window tries to pop-up but finally nothing happens. (I'm running the x64 version on Windows7).
Any hint about this issue will be highly appreciated.
Thank you in advance.
I encounter with the same condition,if anyone can help me?Thank u!
tangshimingyue is offline   Reply With Quote
Old   March 24, 2014, 07:22
denzell
Install a Trial version of Tecplot 360. Your license will only work for a couple days, but on your computer the tecio.dll will be installed which allows SU2 to work even beyond the trial duration.
Old   March 25, 2014, 03:09
yangyang
I am appreciate for your help,I did as what you said above but it does't work. When I run the CFD.exe file,it pop up and vanish rapidly!I wonder if someone ever encountered a similar situation and help me!Thank you all the same.
Old   March 25, 2014, 04:03
denzell
That is expected behavior. It is because by double clicking you do not specify what Config file it should evaluate.
Try this, where I assume your config file such as inv_NACA0012.cfg is located in this folder: C:\SU2\
In Command prompt, enter:
C:\SU2\SU2_CFD inv_NACA0012.cfg
that's right, there is a "space" in between SU2_CFD and inv_NACA0012.cfg
Let me know if you get results now
Old   March 25, 2014, 05:01
Smile
  #26
yangyang
Thank you, But I can't find Command prompt,can you tell me where is it.I use Win7 32 bites OS.
missing dll
SU2 installation on HPC Combas SU2 Installation 1 January 11, 2014 22:14
SU2 parallel installation error JAlbert SU2 Installation 2 November 19, 2013 03:43
[OpenFOAM] Xlib: extension "GLX" missing on display goldbeard ParaView 5 March 24, 2013 14:12
errors when installing openfoam2.1 on ubuntu12.o4 hewei OpenFOAM Installation 5 May 29, 2012 08:43
missing lnInclude files on gentoo ebuild installation BlGene OpenFOAM Installation 1 June 22, 2009 04:59
