August 30, 2013, 05:29 |
Grid partitioning error.
Akash Chaudhari
Rep Power: 13 |
I have compiled the latest version of the code from github and was trying to run the DPW tutorial in parallel. During the partitioning of grid the following error crops up. Code:
------------------------ Divide the numerical grid ---------------------- Finished partitioning using METIS 4.0.3. (73515 edge cuts). Domain 1: 796503 points (18642 ghost points). Comm buff: 72.35MB of 50.00MB. Traceback (most recent call last): File "parallel_computation.py", line 109, in <module> main() File "parallel_computation.py", line 54, in main options.divide_grid ) File "parallel_computation.py", line 77, in parallel_computation info = SU2.run.decompose(config) File "/home.local/akash.chaudhari/Analysis/ver2.0.6/SU2/run/decompose.py", line 66, in decompose SU2_DDC(konfig) File "/home.local/akash.chaudhari/Analysis/ver2.0.6/SU2/run/interface.py", line 68, in DDC run_command( the_Command ) File "/home.local/akash.chaudhari/Analysis/ver2.0.6/SU2/run/interface.py", line 272, in run_command raise Exception , message Exception: Path = /home.local/akash.chaudhari/Analysis/ver2.0.6/, Command = mpirun -np 2 /home.local/akash.chaudhari/SU_CFD/SU2v2.0.6/SU2/SU2_PY/bin/SU2_DDC config_DDC.cfg SU2 process returned error '1' Fatal error in MPI_Bsend: Invalid buffer pointer, error stack: MPI_Bsend(182).......: MPI_Bsend(buf=0x7f065aeb1010, count=6161488, MPI_UNSIGNED_LONG, dest=0, tag=7, MPI_COMM_WORLD) failed MPIR_Bsend_isend(305): Insufficient space in Bsend buffer; requested 49291904; total buffer size is 52430000 Kindly help me solve this problem. Thanks, Akash |
September 6, 2013, 13:43 |
Austin Murch
Rep Power: 14 |
I have also encountered this error when trying to partition a very large grid.
"Comm buff: 130.80MB of 50.00MB" The machine I am running on has 96GB of RAM, so I doubt it is a machine memory issue. |
September 6, 2013, 15:37 |
Austin Murch
Rep Power: 14 |
Line 117 of ../Common/include/option_structure.hpp has
const unsigned int MAX_MPI_BUFFER = 52428800; /*!< \brief Buffer size for parallel simulations (50MB). */ I increased this value to 150MB and the partitioning process gets a little farther (to domain 3 of 8), but then still errors out: [CFD-LINUX:22185] *** An error occurred in MPI_Bsend [CFD-LINUX:22185] *** on communicator MPI_COMM_WORLD [CFD-LINUX:22185] *** MPI_ERR_BUFFER: invalid buffer pointer [CFD-LINUX:22185] *** MPI_ERRORS_ARE_FATAL (your MPI job will now abort) |
September 6, 2013, 16:23 |
Austin Murch
Rep Power: 14 |
After googling "MPI_ERR_BUFFER: invalid buffer pointer", it seems the buffer was still not big enough. So I boosted the MAX_MPI_BUFFER to 1.5 GB, and now my 22M element grid will partition successfully.
SU2 developers: what should this buffer be set to? The maximum grid size we expect? For the record, this 22M element grid is 1.8 GB on the disk in *.su2 format. |
September 7, 2013, 01:40 |
Akash Chaudhari
Rep Power: 13 |
Thanks for your replies Austin. I will try this out on my machine.
[OpenFOAM] Python script to export animation images | mahyarv14 | ParaView | 10 | August 16, 2014 12:11 |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 04:23 |
"No module named libSU2" in py script | shirazbj | SU2 Installation | 3 | February 9, 2013 10:12 |
fireFoam.1.7.x_0.4 compilation error | !link | OpenFOAM Installation | 9 | December 24, 2012 05:15 |
[General] SurfaceFlow filter in python script | yohey | ParaView | 2 | March 18, 2012 08:43 |
