The synthesis problem of x&y-axis response amplitudes in harmonic response analysis |
November 3, 2024, 13:32 |
han wu
Rep Power: 2 |
Thanks in advance for reading my question.
The model is shown in the figure 1. It is a 1D rotor model with different radius of cross sections. 1.JPG Then, I build another cylinder coordinate system beside the default global coordinate system, shown in the figure 2. 2.JPG Therefore, in the cylinder coordinate system, x-axis represents the radial movement, and the y-axis represents the tangential movement (in my own understanding). For the input load, I apply a rotating force alongside the Z-axis (in two coordinate systems, both Z-axis represent the axial direction. After the simulation, I got the frequency response vibration amplitude of each axis. The problem is that the vibration amplitude of the Y-axis and Z-axis in the default global coordinate system do not corresponding to the vibration amplitude of X-axis and Y-axis in the cylinder coordinate system. In my opinion, the vibration amplitude should meet the following equation: (left side represent the default global coordinate system, and the right side represent the cylinder coordinate system) (Y^2+Z^2)^(1/2)=(X^2+Y^2)^(1/2) However, the results are shown below: 3.JPG I wonder why these four figures have the same vibration amplitude. Thanks again for your answering. |
About the harmonic response analysis of a Rotor | hw-Multiphysics | Structural Mechanics | 3 | June 23, 2024 11:41 |
Turbulent NACA 64-A010 stability response problem | kiloWatt | SU2 | 0 | December 1, 2020 14:26 |
SU2-7.0.1 on ubuntu 18.04 | hyunko | SU2 Installation | 7 | March 16, 2020 05:37 |
Axis treatment in axisymmetrical problem | Jakob1 | OpenFOAM Pre-Processing | 2 | August 25, 2014 04:09 |
