Home > Forums > General Forums > Structural Mechanics
Explicit time integration of shells without "drilling" DOF
Old   September 17, 2024, 07:56
Default Explicit time integration of shells without "drilling" DOF
Anders Aamodt Resell
ander is on a distinguished road
A number of shell elements have only 5 degrees of freedom (3 translations and 2 rotations). In explicit FEM, it is common to use the central difference method, and for instance in the paper of Belytschko et. al. https://doi.org/10.1016/0045-7825(84)90026-4 it is stated that this method is used.
However, to me it doesn't seem trivial to extend the central difference method for translational DOFs to a setting with rotational DOFs, ESPECIALLY when there are only two rotational degrees of freedom. I have some idea of how this can be done with three rotational DOFs, then you can use an exponential map to update a rotation matrix or quaternion that describes the nodal rotation.
If someone has any pointers or sources on how this can be done in the 5 DOF setting, I would be happy to hear it.
ander is offline   Reply With Quote
central difference, drill, rotations, shell
bash script for pseudo-parallel usage of reconstructPar kwardle OpenFOAM Post-Processing 42 May 8, 2024 00:17
Slow calculation time on CFD server killian153 Hardware 4 July 27, 2021 08:28
pressure in incompressible solvers e.g. simpleFoam chrizzl OpenFOAM Running, Solving & CFD 13 March 28, 2017 06:49
same geometry,structured and unstructured mesh,different behaviour. sharonyue OpenFOAM Running, Solving & CFD 13 January 2, 2013 23:40
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
